Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 12-11-2019, 06:59 PM
AxiomDesignGroup AxiomDesignGroup is offline
Default Intermittent Ring-Modulated/Bit Crushed Playback of Recorded Audio
Hi, Everyone!
Longtime lurker, first time poster... I've been using Pro Tools for 20 years now and never run into this level of aggravation.
I'm having a serious issues with my brand new HDX system.
All recorded audio (even recorded internally using just a signal generator, or any other source) is bitcrushed and appears to be dropping samples, resulting in a ring-modulated/distorted sound when played back and a waveform that appears to be a mix of saw and square waves. This happens nearly everytime I record anything. It is not a clock mismatch issue.
(Please see attached images and audio clips below)
The only temporary fix I've come across is constantly changing the buffer size in playback engine, but this is ridiculous and counterproductive to actually running any kind of business with Pro Tools HDX at the studio core. I would add that this happens with ZERO plugins running.
Imagine capturing the perfect song-length vocal take, only to discover that the ring-modulated recording error has returned... "Ooops, sorry - Cut it again" followed by 30 seconds of quality recorded audio... followed by "Oops, sorry - cut it again" after changing the buffer setting again. Completely unacceptable.
I've ruled out my external hardware (I/O 8x8x8) by recording a known-to-be-clean signal from within the software to another track within itself and gotten the same result. I also get the same messed up audio when using Adobe Auditon, Ableton Live 10 and Adobe Premiere with the HDX card. When I swith to the built in RealTek HD, everything records plays back with ZERO issues... but using that defeats the entire purpose of an HD system!
The techs at Sweetwater have been great, but I'm having a lot of trouble getting follow up response from Avid tech support since my first callback when this problem initially popped up.
They've recommended several basic things that I had pretty much already done before contacting them:
1- Trash prefs
2- Try putting the HDX card in Slot 4
3- Try reinstalling pro tools and all related drivers (I've done this SIX TIMES now)
4- Update your Z440 bios
5- Check for and activate any Windows or driver updates
6- Use HP Advisor to set your bios settings to Avid's recommendations
http://avid.force.com/pkb/KB_Render_...qTV&lang=en_US
7- Turn off "Ignore Errors during playback"
8- Follow the Windows 10 Optimization settings http://avid.force.com/pkb/articles/t...ndows-10-Guide
I even had a replacement HDX Core card sent, to no avail.
So....
Now I've had an HDX system with a Perpetual Ultimate License for a month and a half that has been completely unusable... which is eating into my license time and more importantly, my income.
I've read an insane amount of posts on here (and on Reddit + Gearslutz) of people having similar issues and nobody from Avid EVER comments or offers even a hint of how to resolve this issue that has spanned years, different verions of Pro Tools (frome LE to HDX) and different interfaces.
A few examples:
http://duc.avid.com/showthread.php?t=360282
http://duc.avid.com/showthread.php?t=383533
http://duc.avid.com/showthread.php?t=383449
http://duc.avid.com/showthread.php?t=399750
http://duc.avid.com/showthread.php?t=376903
http://duc.avid.com/showthread.php?t=355852
http://duc.avid.com/showthread.php?t=401332
http://duc.avid.com/showthread.php?t=364669
http://duc.avid.com/showthread.php?t=377162
http://duc.avid.com/showthread.php?t=373139
I have a support contract with Avid and when I call the number they say to use for Audio Help and press the correct numbers at the prompts, I keep getting video "techs" after waiting an hour++ per call... only to discover that they aren't even really techs - All they do is update your case with new information and tell you that, "Sorry, I am unable to transfer you to anywhere else in our system"
I can't even see or interact with my case # because the initial case was setup up by Sweetwater tech support and it's not even listed in my Avid Support Profile. During BOTH of my attempts to get an Avid tech that would be useful yesterday, they both said they would attach the case to my account. I'm still waiting.
As I mentioned above, people have recommended constantly changing the buffer size, but that is a band-aid/workaround, NOT a solution. For the amount it costs to have a system like this, Avid's engineers should be on top of this and corporate should should let their dedicated customer base know that it is a recognized issue/bug.
I'm really not trying to be a jerk here, but I am beyond aggravated and a total loss for how to proceed. I've been going around in circles with them for weeks on end and I'm losing projects left and right. Clients will only be so understanding for so long.
Any ideas?
Thank you so much!
-Jason
SANDRA REPORT:
ID
Host Name : STUDIO
Workgroup : WORKGROUP
Computer
Model : HP Z440 Workstation 103C_53335X G=D
Serial Number : USH84*****
Chassis : HP Mini Tower
Mainboard : HP 212B
BIOS : HP M60 v02.50 11/07/2019
TPM - Trusted Platform Module : IFX 1.2 (PCR 24)
Intel vPro : 9.1.42.3002
NUMA Support : 3 Unit(s)
Total Memory : 64GB ECC DIMM DDR4
Processors
Processor : Intel(R) Xeon(R) CPU E5-1660 v4 @ 3.20GHz (8C 3.2GHz, 2.7GHz IMC, 8x 256kB L2, 20MB L3)
Socket/Slot : FC LGA1150
Chipset
Memory Controller : HP Xeon (Broadwell-E) DMI2 100MHz
Memory Controller : Intel Xeon (Broadwell-E) Memory Controller 0 - Target Address/Thermal/RAS 100MHz, 4x 16GB ECC DIMM DDR4 2.4GHz 256-bit
Memory Controller : Intel Xeon (Broadwell-E) Target Address/Thermal/RAS 100MHz
Memory Module(s)
Memory Module : Samsung M393A2K43BB1-CTD 16GB ECC DIMM Registered DDR4 PC4-21300R DDR4-2666 (19-19-19-44 4-63-21-7)
Video System
Monitor/Panel : LG IPS235
(1920x1080, 23.1")
Video Adapter : NVIDIA Quadro P600 (3CU 384SP SM6.4 1.33GHz/1.56GHz, 512kB L2, 2GB 4GHz 128-bit, PCIe 3.0 x16)
Graphics Processor
CUDA : NVIDIA Quadro P600 (384SP 3C 1.33GHz/1.56GHz, 512kB L2, 2GB 4GHz 128-bit)
OpenCL : NVIDIA Quadro P600 (384SP 3C 1.33GHz/1.56GHz, 512kB L2, 2GB 4GHz 128-bit)
D3D 11 : NVIDIA Quadro P600 (384SP 3C 1.33GHz/1.56GHz, 512kB L2, 2GB 4GHz 128-bit)
OpenGL : Quadro P600/PCIe/SSE2 (2GB)
Storage Devices
Samsung SSD 970 EVO Plus 1TB (1TB, PCIe3x4/NVMe, SED) : 932GB (D:)
Samsung SSD 860 EVO 1TB (1TB, SATA600, 2.5", SSD, OPAL) : 932GB (C:)
hp HLDS DVDRW GUD1N (RAID, DVD+-RW, CD-RW, 512kB Cache) : N/A (E:)
Logical Storage Devices
WORK DRIVE (D:) : 931GB (NTFS, 4kB) @ Samsung SSD 970 EVO Plus 1TB (1TB, PCIe3x4/NVMe, SED)
Recovery : 529MB (NTFS, 4kB) @ Samsung SSD 860 EVO 1TB (1TB, SATA600, 2.5", SSD, OPAL)
SYSTEM DRIVE (C:) : 931GB (NTFS, 4kB) @ Samsung SSD 860 EVO 1TB (1TB, SATA600, 2.5", SSD, OPAL)
Hard Disk : 95MB (FAT32, 1kB) @ Samsung SSD 860 EVO 1TB (1TB, SATA600, 2.5", SSD, OPAL)
Optical Drive (E:) : N/A @ hp HLDS DVDRW GUD1N (RAID, DVD+-RW, CD-RW, 512kB Cache)
Peripherals
LPC Hub Controller #1 : HP Wellsburg LPC Controller
Audio Device : HP Wellsburg HD Audio Controller
Audio Codec : Realtek Semi High Definition Audio
Audio Device : HP GP107GL High Definition Audio Controller
Audio Codec : nVidia nForce MCP2S PCI to ISA Bridge
Serial Port(s) : 1
Disk Controller : HP Wellsburg sSATA RAID Controller
Disk Controller : HP Patsburg SATA RAID Controller
Disk Controller : Samsung NVMe SSD Controller SM981/PM981
USB Controller #1 : HP Wellsburg USB xHCI Host Controller
USB Controller #2 : HP Wellsburg USB Enhanced Host Controller #2
USB Controller #3 : HP Wellsburg USB Enhanced Host Controller #1
SMBus/i2c Controller #1 : Intel ICH SMBus
SMBus/i2c Controller #2 : Intel MCP5-E(P) XMB Ch 0 SMBus
SMBus/i2c Controller #3 : Intel MCP5-E(P) XMB Ch 1 SMBus
Printers and Faxes
Printer : Microsoft Print To PDF (600x600, Colour)
Network Services
Network Adapter : Intel(R) Ethernet Connection (2) I218-LM (Ethernet, 1Gbps)
Wireless Adapter : Realtek 8812AU Wireless LAN 802.11ac USB NIC (802.11ac (VHT), AES-CCMP, 390Mbps)
Operating System
Windows System : Microsoft Windows 10 Professional 10.0.18363
Platform Compliance : x64
HP PERFORMANCE ADVISOR REPORT
Computer Name: STUDIO
Model: HP Z440 Workstation
Computer Type: Desktop
Manufactured by: Hewlett-Packard
Baseboard ID: 212B
Serial Number: USH845L0T7
BIOS version: M60 v02.48 (Current Setting Group: Pro Tools)
Processor: Intel(R) Xeon(R) CPU E5-1660 v4 @ 3.20GHz
Enabled Processor Count: 8
Total Memory: 64 GB
Local Storage: 1.82 TB (2 drives)
Graphics Card & Driver: Quadro P600 -- 440.97
Slots in use:
SLOT 2 (PCI Express Gen 3): NVIDIA Quadro P600
SLOT 3 (PCI Express Gen 2 x8): Avid HDX
SLOT 4 (PCI Express Gen 3): Standard NVM Express Controller
Operating System: Windows 10 (64-bit) - Microsoft Windows 10 Pro for Workstations
Current Culture: en-US
.NET Framework: 528040
Current Active Power Scheme: High performance (GUID {8c5e7fda-e8bf-4a96-9a85-a6e23a8c635c})
HP Performance Advisor: 2.1.4431.0 (Database Timestamp: 11/18/2019 5:07:25 PM)
Proxy server: No proxy server
Installed Applications: Adobe Premiere Pro CC
Avid Pro Tools
Socket Designation: CPU0
Socket Status: CPU Socket Populated
Manufacturer: Intel(R) Corporation
Type: Central Processor
Family: Intelฎ Xeon™
CPU ID Values: EAX: 000406F1 -- EDX: BFEBFBFF
CPU ID Family/Model/Type Designator: 0x06 0x4F 0x00
CPU ID Signature: 0x406F1
Version: Intel(R) Xeon(R) CPU E5-1660 v4 @ 3.20GHz
Version Details: Intel64 Family 6 Model 79 Stepping 1
CPU Revision: 20225
Voltage: 0.8 v
External Clock: 100 MHz
Nominal Speed: 3.2 GHz
Max Speed: 3.2 GHz
Min Speed: 3.2 GHz
Core Count: 8
Cores Enabled: 8
Thread Count: 8
EM64T Capability: Available
HyperThreading Capability: Available
HyperThreading Status: Disabled
OS Type (Physical/VM): Physical
L1 Unified Cache: 512 KBytes (524,288 Bytes) (as reported by Windows)
L2 Unified Cache: 2 MBytes (2,097,152 Bytes) (as reported by Windows)
L3 Unified Cache: 20 MBytes (20,971,520 Bytes) (as reported by Windows)
Physical CPU Range: CPU0, Physical CPUs (APIC#0-0 through APIC#0-0)
Per-CPU Cache, DTLB : 4KB pages, 4-way associative, 64 entries
Per-CPU Cache, PreFetching : 64-byte prefetching
Vendor: Hewlett-Packard
Version: v02.50 REV A
Release Date: 11/12/2019
Starting Address Segment: 0xF000
ROM Size: 16 MB
Image Size: 64 KB
Embedded Firmware Controller Release:
Characteristics: • PCI is supported
• Plug and Play is supported
• BIOS is upgradeable (Flash)
• BIOS shadowing is allowed
• Boot from CD is supported
• Selectable boot is supported
• EDD (enhanced disk drive) specification is supported
• Int 5h, Print Screen service is supported
• Int 9h, 8042 Keyboard services are supported
• Int 14h, Serial services are supported
• Int 17h, Printer services are supported
• ACPI is supported
• USB Legacy is supported
• BIOS Boot Specification is supported
• Function Key Initiated Network Service boot is supported
• Enable Targeted Content Distribution
Plug-and-Play ID: PCI\VEN_10DE&DEV_1CB2&SUBSYS_11BD103C&REV_A1\4&168 66DE7&0&0010
Graphics Card Provider: HP (103C)
Device Registry Key: System\CurrentControlSet\Control\Video\{7880FED9-F799-11E9-9D24-CEE194B99015}\0000
Registry Adapter String: Quadro P600
Registry Firmware Version: Version86.7.3b.0.45
Registry Chip Type: Quadro P600
Registry DAC Type: Integrated RAMDAC
Memory Size: 2 GB
Video Mode: 1920 x 1080 x 4294967296 colors
Driver File Version: 26.21.14.4097
Familiar Driver Version: 440.97
Graphics API Capable: True
SLI Enabled GPUs: False
Memory - 64 GB (16 GB chips in DIMMS 1/3/6/8)
PRO TOOLS SOFTWARE & CONNECTED HARDWARE:
PT 2019.10
HDX CORE CARD
HD I/O 8x8x8
AVID Pre
(2) Artist Mix Units
Roland Integra 7
MOTU MTP-AV
Old 01-20-2020, 11:10 AM
Default Re: Intermittent Ring-Modulated/Bit Crushed Playback of Recorded Audio
Strange indeed Here's what has me confused:
Processors
Chipset
Memory Module(s)
I'm far from being an expert, but the report makes me suspect a RAM problem. One line reports 64 GB of RAM, but later, the report only shows a single 16GB stick(where it should show 4), assuming all 4 sticks of RAM are identical(which they SHOULD be). I would remove 2 sticks and install 2 in the correct slots for using 2 sticks. If that doesn't help, pull those 2 and try the other 2 sticks. You might need to go online to get details on the specific motherboard you have(so you know which RAM slots to use for only 2 sticks).
Old 06-01-2020, 02:46 PM
Michael_S Michael_S is offline
Hey there,
Did you find any solution for this issue as I‘m facing the same problem.
Also working on Windows 10 with a HP Z440 Workstation with ProTools Ultimate 2020.5 on HDX with a Focusrite Red4Pre Interface.
The distorted, ringmodulated, Bit-Crushed sound appears when bouncing offline, online and even when bussing and recording into an audio-track.
Whats interesting is, that playback is running smooth, but the recordings and bounces are damaged.
Whats further interesting is, when recording M&E, Mix and VO busses at the same Time, the routing of the bussing goes nuts and ends up with e.g. right side of the mix-bus going to the VO-Bus. Let alone the mangled sound.
So far I could verify that the Focusrite is working properly as I did some tests via Thunderbolt on a MacBookPro.
Also ProToolsSoftware seems to work, as I had to switch the system back to the RME Interface I used before. (In the middle of a project with customers hearing that extreme destroyed sound coming out of a very expensive workstation)
As proposed I also did the changes and optimizations for the BIOS with no luck.
So on Friday I gave up and ordered another HDX card for testing.
After reading these entries I have little hope, that the new card will be solution for my problems. So any help is appreciated as the next project is round the corner.
Thanks for any advice.
Michael
Eucon 2020.5
Windows 10
HP Z440
32GB RAM
6Core 3.2GHz
Focusrite Red4Pre
ProTools HDX
RME UC
Avid S1
Avid Dock
Old 06-09-2020, 09:23 AM
Steven1145 Steven1145 is offline
Looks like I'm having the same issue, but on the inputs of my hdx card. Our stem recorder will start fine, but suddenly it goes haywire and I get exactly what you are experiencing.
Steven Ghouti, Re-recording Mixer, Yellow Cab Studios
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 06-26-2020, 12:44 AM
Just a quick update as we are experiencing the same thing here.
We do film post mixing, so the HDX system is used as a stem recorder (recording 5.1 and 7.1 stems most of the time).
First time the issue popped up was on a home-built PC, and we were recording 7x 5.1 stems for a movie. We tried lots of things, and thinking that the issue was a compatibility thing with the Motherboard we decided to swap for an old Mac Pro 5.1 for the remainder of the movie.
The Mac Pro used the same HDX card, cables and audio interface (DAD DX32), and had no issues.
As the Mac Pro was a bit old, I decided to buy a used Z440 (approved) to use as a stem recorder. We received it this week, and did all the BIOS edits required by the ProTools compatibility documents.
Installed the HDX card, and fired up the same 7x 5.1 stem session. SAME ISSUE AGAIN!
We did not have the problem on Mac at all.
So we are now looking a bit deeper into it, and tested with a single 5.1 track in record, and had no issues.
I'm starting to think that maybe HDX on Windows has an issue with more than 2 digilink connectors used as inputs?
I'll keep testing and let you know.
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 06-26-2020, 04:44 AM
UPDATE:
Talked it over with the tech at local company 44-1, and he said he had a similar issue not so long ago, that was resolved by changing the NVIDIA video card driver for the Quadro K2200.
What he had me do was try one of two that he knew worked. These are actually quite old drivers.
391.33 (this is the one I installed)
412.16
We have the stem recorder running for nearly two hours now with 7x 5.1 stems in record with NO glitches or channel swaps.
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
Old 07-02-2020, 04:41 AM
So I tried an tested the advice with the older NVidia-Driver.
Same issues as before.
Even after a remote-session with AVID yesterday, the issues appear.
Sometimes it'll work for a few minutes, sometimes the distortion and bus-juggling appears a few seconds after start-up.
This is really annyoing.
Help very appreciated.
Eucon 2020.5
Windows 10
HP Z440
32GB RAM
6Core 3.2GHz
Focusrite Red4Pre
ProTools HDX
RME UC
Avid S1
Avid Dock
Old 08-31-2020, 11:46 AM
ulisauer ulisauer is offline
Hi, did you guys find a solution to this, is there a reason for the error?
We just had the error today on our HDX Win 10, Nvidia GTX1070 August driver installed.
Old 09-03-2020, 12:44 PM
As I said, the proper driver and video card solved it here. But I'm speechless at how unresponsive AVID are for this sort of issue which basically renders the whole system unusable.
Envoy้ de mon SM-G981B en utilisant Tapatalk
Steven Ghouti
YELLOW CAB Studios
Paris, France
The studio FB page
During recording, audio sounds fine, during playback, it sounds bit crushed JJTaylor Pro Tools 11 16 03-08-2017 05:05 AM
Reopening sessions have ring-modulated distortion SomeOtherGuy Pro Tools HDX & HD Native Systems (Mac) 6 10-31-2014 09:17 AM
Intermittent loss of audio playback Stormfront 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-24-2010 09:24 PM
Intermittent audio "spikes" when starting playback ensonix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-14-2005 10:27 AM
