Old 01-04-2019, 10:48 AM
kosmokrator kosmokrator is offline
Default exit expand
Hey,
I'd love a way to exit (auto) expand mode by a button that is closer to the center section than the expand knob on the channelstrip. That one is a real arm killer.
Any way to program that to a soft key or alternatively use esc or something similar?
Old 01-04-2019, 10:52 AM
its2loud its2loud is offline
Default Re: exit expand
I agree. Maybe a Shift+Focus button to close expand?
Old 01-05-2019, 08:55 AM
creativecontrol's Avatar
So, if there existed a Surface Soft Key function which was assignable that performed the function of close all locally assigned Expand Zones, would that be desirable? Obviously for dedicated on Attention expand zones those are fixed, addressable and can be defeated by the user.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-05-2019, 09:40 AM
Yes. For example. Dedicated on attention expand zones are already assigned to EQ and DYN. When hitting exp on a channel strip for say a reverb or other insert it would be nice to close the expand in a way that isn’t such a reach to the exp key again. Additionally, it would be nice to expand in the same way. Perhaps it performs as a toggle as previously mentioned as Shift+Attention. Alternatively, could the expand function work if a control knob for insert selection is depressed for a specified amount of time? Quick depression expands on strip knobs, 2 sec depression expands on entire knob module?
Thank Jeff.
Old 01-05-2019, 10:14 AM
That’s an intriguing idea with the press and hold function for Insert Params.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-05-2019, 10:22 AM
Thanks. I think it would be a very useful feature. Once expanded, a press and hold on any knob would then collapse expand mode back to strip mode. Just a thought.
Old 01-06-2019, 01:21 AM
Yes, that would be great. Another option would be to use the 'config' button that is already used to collapse auto expand inserts back to the inserts overview.
The 'hold' idea is also great. And FWIW, I don't like any 'shift'-combinations for functions that are needed quite often.
Old 01-06-2019, 07:23 AM
I agree that two handed or two fingered gestures are less than desirable and tend to attenuate efficiency. I would also personally suggest a user assignable Surface function which could be parked anywhere on the Locate, Transport, Master Module or Automation Module assignable locations.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
App crash on exit PT 9.0.6 elmodagansta Windows 3 07-16-2014 10:41 AM
Lockup on Exit drasmith Windows 0 12-17-2010 06:31 PM
Could not complete exit Heydrich 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-21-2006 05:11 PM
Locks up on exit Princeton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-25-2002 08:53 PM
exit PTF -> freeze! clausiii Digidesign Hardware & Software 0 11-12-2001 03:07 AM
