Closed Thread
Old 05-19-2017, 01:09 PM
creativecontrol's Avatar
Default S6 faq
Support:
http://avid.force.com/pkb/articles/e...vid-S6-Support
Compatibility:
https://avid.secure.force.com/pkb/ar...-Compatibility
File Locations:
Layouts:
C:\ProgramData\Avid\S6\Titles\
S6 System Prefs:
(Monitoring, Surface Config, Network, Expected Workstations..)
S6 User Prefs:
C:\Users\S6User\AppData\Local\Avid\S6
S6 Soft Keys:
C:\ProgramData\Avid\S6\AppSets\
Default Appsets:
Licenses:
C:\ProgramData\Avid\Licenses\S6
MTM Logs:
C:\Users\S6User\AppData\Local\Avid\Logs\S6
Crash Reports:
C:\Users\S6User\My Documents\Avid_CrashReports
Log Files:
http://avid.force.com/pkb/articles/e...g/S6-Log-Files
Activation:
http://avid.force.com/pkb/articles/e...ctivation-Card
System ID:
http://avid.force.com/pkb/articles/e...d-S6-System-ID
S4 & S6 Operation 23.6:
https://www.dropbox.com/scl/fi/6krvd...yfv404czj&dl=0
S4 & S6 History:
https://www.dropbox.com/s/1zkvn6v9uf...story.pdf?dl=0
EUCON Product Guides:
https://avid.secure.force.com/pkb/ar...Product-Guides
Monitor Section Locking:
http://avid.force.com/pkb/articles/e...se&subfilters=
Configuring Sources - MTRX & S6:
http://avid.force.com/pkb/articles/e...s-MTRX-with-S6
Creating a new DADman Monitor Profile:
http://avid.force.com/pkb/articles/e...Pro-Tools-MTRX
Service Guides:
https://avid.secure.force.com/pkb/ar...Service-Guides
S4 S6 Module Compatibility
Module Replacement:
http://avid.force.com/pkb/articles/e...le-Replacement
Module & Frame Dimensions:
https://cdn-www.avid.com/-/media/avi...moduledims.pdf
Power and Weight Specifications:
http://akmedia.digidesign.com/suppor...ight_94769.pdf
Changing MTM Port 1 to Static IP:
http://avid.force.com/pkb/articles/e...1-to-Static-IP
Expanding an S6 System Guide PDF
http://akmedia.digidesign.com/suppor...stem_88549.pdf
Surface Expansion & Config for M10 & M40 Systems
https://www.dropbox.com/s/5odpwaqbax...nfigs.pdf?dl=0
Library of Example Layouts, Sessions, Soft Keys, Videos and Monitor Profiles
https://www.dropbox.com/sh/k8myeuvzf...LhmEpvQDa?dl=0
S4 S6 Tips of the Day Videos
https://www.youtube.com/playlist?lis...S5l5tYDwg7zZqV
Custom Furniture Guidelines:
http://avid.force.com/pkb/articles/e...ategory=Audio;
S4 S6 Riser Kits Installation Guide:
http://resources.avid.com/SupportFil...tion_Guide.pdf
3rd Party Furniture:
Argosy Consoles
AKA Design
Soundz Fishy
Modson Studio Furniture
Sterling Modular
UPPEAL Floor Sit Stand Desks
Zaor Studio Furniture
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-23-2017, 04:47 AM
Postman Postman is offline
Default Re: S6 faq
I nominate this to become a sticky
system specs in profile
Old 05-23-2017, 04:49 AM
Drew Mazurek's Avatar
Default Re: S6 faq
Done.
www.drewmazurek.com
Old 05-23-2017, 04:50 AM
Marsdy Marsdy is offline
Default Re: S6 faq
Me too. I've already subscribed to some of these pages to get update notifications. Thanks Jeff.
Dave Marsden
UK
Old 08-07-2018, 06:18 AM
Default Re: S6 faq
Added a doc showing a comparison of the expansion options for M10 & M40.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-31-2018, 08:42 AM
Default S6 faq
Linked Library of example Titles, Layouts, Sessions, Soft Keys sets, Videos and Monitor Profiles added.
S6 Troubleshooting document added.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-31-2018, 09:30 AM
Default Re: S6 faq
Jeff,
To be clear, those folders are supposed to be empty now?
www.drewmazurek.com
Old 03-15-2019, 08:25 AM
Default Re: S6 faq
Greetings,
I've added several example Monitor Profiles for MTRX to the Resource Library. The first is a Basic Stereo configuration shown here:
Stereo_Basic represents a simple Stereo Monitor Profile with a Control Room and 4 Cue Monitors named MonA through MonD. The Control Room includes a Stereo Source via Digilink named PTHD as well as 3 pairs of stereo Dante paths leveraging Dante Virtual Soundcard (these could be iTunes, SoundMiner, etc.) MonA through MonD are designated as CUE (Set Monitor Mode = Cue) such that they could optionally be fed back into the Control Room (add existing source -> MonA for example) so that the engineer could QC exactly what the talent is hearing. MonA through MonD share the Pro Tools and DVS sources but also add individual Mic inputs and Talkback. Each of the 4 Cue Monitors feed outputs to stereo Dante streams, with the presumption that a Focusrite or KLANG headphone DA will be used. Mono FoldDowns are included for both the Control Room and the 4 Cues.
5.1_SMPTE represents a 5.1 Monitor Profile which includes all 6 channel wide input sources including Pro Tools via Digilink, DVS, and multiple coaxial MADI streams which could originate from additional source workstations for example. The Main Output is a 6 channel analog output set in SMPTE order and typical 5.1 to X FoldDowns are included. A pre-fader external Meter path is also defined for a RTW TM3 connected via AES-EBU on the chassis. 2 Cue Monitors for Headphone stations are included with the presumption that they will feed Dante based headphone DA's like a Focusrite AM2. 5.1 to Stereo FoldDowns are included. The Control Room sources are shared with both MonA and MonB.
Monitor Profiles:
https://www.dropbox.com/sh/c614lenxl...PRqf0SjKa?dl=0
Last, when loading these Monitor Profiles, expect to receive an error message since they originated from a different serial number unit than yours. Simply press Cancel, go to Settings > Monitor Profile and tick Enable monitor.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-29-2021, 09:26 AM
Default Re: S6 faq
Added S4 • S6 History document to the primary FAQ.
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Closed Thread
