Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 12-01-2022, 09:26 AM
creativecontrol's Avatar
Default MTRX Family Devices: Start Here!
Welcome to MTRX Family Devices!
It is highly recommended to be running the latest version of DADman -> v5.8.0.8 with your MTRX Family device, which you can access via your Avid Account or from the Download Center.
Current Firmware + Driver Versions
MTRX: 2.4.4.1
MTRX II: 1.1.0.3
MTRX Studio: 1.1.5.1
TB3 CoreAudio Driver: 1.2.2
TB3 ASIO Driver: 1.1.2
Audinate Brooklyn II Module: 1.0.2.1
Audinate Brooklyn III Module: 1.1.0.2
Other
MOM: 1.0.1.4
Best Practices and General Recommendations
Don't use Migration Assistant when building a new macOS workstation.
If you don't explicitly need the HD Core Audio driver, disable Avid Audio Server.
Make sure to set the Unit Name and Unit ID - especially with multiple MTRX Devices for differentiation under DADman > Settings > Device List.
If TB3 option in MTRX II or MTRX Studio the device will connect via that bus. If IP, use either manual / static IP addressing or DHCP via a router. Self-Assigned not recommended.
Make sure you know where your patch (.dms) and monitor (.dmprof) data files are being stored. Recommend to build a subfolder under /Users/yourusername/Documents/ for your files.
DVS (Dante Virtual Soundcard) is convenient for system audio, but often problematic from a compatibility perspective. Consider at least an Audinate AVIO USB adapter as an alternative.
Recommend turning Auto Save for .dms and .dmprof OFF in DADman, then explicitly making changes to the files. When performing a firmware update, once finished - click reboot then quit DADman and wait till you see / hear the device fully reboot. Open DADman now with Auto-Load preferences set to restore your last good .dms and .dmprof file.
Support Information
MTRX & MTRX Studio Support Information
Release Notes for DADman v5.8.0.8
Release Notes for DADman v5.7.2
DADman Release Notes Index
MTRX Family FAQ
Sample Rate Conversion with MTRX options
Avid Knowledge Base: MTRX
What is DADLink?
DADLink Technical Notes - Format + SFPs
AES/EBU Cable Guide Reference
Tutorial Documents:
MTRX Family Knowledge Resource
Monitor Profiles
MTRX Family Monitor Profiles (.dmprof)
Audinate Dante Solutions
Dante Controller
Dante Via
Dante AVIO Adapters
Network Basics FAQ
Jochen Schulz BLOG - IP Audio
Controlling Monitor Profiles
Avid S6
Avid Control
MOM: Monitor Operating Module
MOM App
Stream Deck +
SoundFlow Scheps MOMDeck
MOM StreamDeck Plugin - Luke Howard
Problem Solvers
Audiomovers Omnibus 3
Lockstep
AudioMovers Binaural Renderer for Apple Music
Embody: Immerse Virtual Studio
Documentation
MTRX II Guide
MTRX Installation Guide
MTRX Operation Guide
MTRX Studio Installation Guide
MTRX Studio Operation Guide
Video Resources
MTRX In Focus Playlist
MTRX Studio Playlist
MTRX Studio: Get Up & Running
MTRX Studio: Thunderbolt 3 Workflows
MTRX II Up & Running: Setting up for Dolby Atmos
MTRX II: Overview
MTRX Tutorial Library at Avid
Coffee & Consoles: Getting the Most out of MTRX Devices
DAD MOM Controller Playlist
Scheps MOMDeck Tutorial V2
MTRX Brain Tips
Creating a Monitor Profile with MTRX
Locking MTRX Devices with DADman via EuControl
MTRX Comprehensive Overview
Speaker Calibration
Sonarworks SoundID Reference
Room EQ Wizard
Rational Acoustics: Smaart
Dolby Atmos
Dolby Atmos Renderer
Dolby Atmos Album Assembler
Dolby Atmos Conversion Tool
Dolby Atmos Personal HRTF
Requirements for a Dedicated Dolby Atmos Renderer
Dante SRC Solutions
Studio Technologies 48D Dante Bridge
Studio Technologies 5842 Dante Bridge
Appsys Pro Audio: FLX-DANTE
DirectOut: EXBOX.MD
Dante Headphone Solutions
KLANG:quelle
Focusrite: RedNet X2P
Hear Technologies: Hear Back PRO
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-20-2023, 08:15 AM
Default Re: MTRX Family Devices: Start Here!
Greetings,
Here's a set of simple Monitor Profile templates for use with MTRX Studio and the Internal Renderer in Pro Tools 23.12:
https://www.dropbox.com/scl/fo/io4jw...mmyqustiv&dl=0
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-05-2024, 01:15 PM
Greetings,
Here's an example MTRX II Monitor Profile for working in 7.1.4 for both the Internal and External Dolby Atmos Renderer, plus additional accommodations for Stereo Ref, Dolby BIN, 2.0, and spatial audio returns to the headphone cues. This profile includes example tunings and bass management for the 7.1.4 monitor set.
https://www.dropbox.com/scl/fi/sab4s...wj48dg5fu&dl=0
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-05-2024, 02:17 PM
uptheoctave uptheoctave is offline
Originally Posted by creativecontrol View Post
Greetings,
best,
Jeff
Awesome.
Thanks.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest article: Multichannel Monitoring with Avid MTRX II
Old 02-07-2024, 02:54 AM
IrelandM IrelandM is offline
Hi Jeff,
Is the ''example MTRX II Monitor Profile for working in 7.1.4''usable on the MTRX Studio if tweaked.
Regards
Old 02-07-2024, 03:59 AM
You would be better served starting with a profile from the MTRX Studio folder:
https://www.dropbox.com/scl/fo/oaa8a...2ubce1dxd&dl=0
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-14-2024, 09:17 AM
MTRX I Firmware v 2.4.2.2 is now available and is highly recommended. Use DADman 5.7 to update your device with the new firmware package which you can access via your Avid Account or from the Download Center.
** A timing and format error in the DigiLink interface has been corrected. The change is only relevant for
MTRX. In the previous firmware version 2.4.1.2 a bug on the DigiLink interface occurred.
The bug is not in the earlier versions. This is corrected in the new version. **
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-18-2024, 08:55 AM
Check this space for more educational applications and use cases for deploying and using MTRX Family devices.
https://drive.google.com/drive/folde...usp=share_link
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX MTRX Studio Forum Section? off the wall Pro Tools | MTRX & MTRX Studio 2 05-08-2022 03:20 PM
MTRX Sources - >Trinnov MC16 Dante ->MTRX Out routing ??s Jeff Schmidt Pro Tools | MTRX & MTRX Studio 4 03-18-2022 02:21 PM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
Video Capture Devices - where do I start? spicyitaliano General Discussion 8 07-23-2005 12:55 PM
