  #21
Old 11-29-2022, 01:51 PM
budster budster is offline
Default Re: Audiosuite Plugins Greyed out
I have the same issue on M1 Mac Studio and PT Ult 2022.7 HDX2.
  #22
Old 11-30-2022, 05:36 AM
Ben Jenssen's Avatar
I can't see anyone in the thread mentioning whether they can select an Audiosuite plugin with the names in this grey state, or not. I sometimes see the whole PT menu bar in grey, but when I click it, it 'wakes up' and everything is normal. PT 2020.12, Big Sur.
  #23
Old 11-30-2022, 07:41 PM
nednednerb's Avatar
nednednerb nednednerb is offline
When I see the greyed items, I can totally still click them and open the audiosuite plugin window. It doesn't seem to ever "wake up" but changing system and PT "light and dark modes" back and forth seems to randomly set things right (for a time).
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
  #24
Old 12-01-2022, 11:42 AM
Ceeze Ceeze is offline
I got a response from Avid saying the bug has been resolved in the 2022.10 release, which I can confirm I have not seen happen since.
Here is the bug number for this issue: PT-290335
  #25
Old 12-01-2022, 12:22 PM
creativecontrol's Avatar
That is correct. Mentioned in the Release Notes:
Pro Tools 2022.10 Release Notes
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #26
Old 12-05-2022, 07:36 PM
bigpocketmusic bigpocketmusic is offline
Originally Posted by TimNielsen View Post
This bug occurs when you change the sample rate of a new session, or open a session with a different sample rate. Quitting ProTools and relaunching it fixes it. until you change sample rates again.
Truly astonishing that bugs like this exist and MORE ASTONISHING that they can persist over several versions of the program.
This bug has been reported, but don't think it will be fixed even in the next version
Thank you TimNeilson for this insight.
This issue happened to me today and the problem WAS the sample rate somehow got changed. I took a look at MBOX Control and confirmed that the sample rate had changed. I changed it back to 48k and the AudioSuite menu was no longer Greyed out after restarting Pro Tools.
Oddly, in the past with my other interface (RME MADI FX ) Pro Tools would warn me if I opened a song that had a sample rate that differed from what that interface was set to. The Mobx Studio interface did not trigger a warning about the sample rate.
I'm on an M1 MacBook Pro using Pro Tools 2022.10 and the interface is the new Box Studio.
Best Regards 😊
  #27
Old 01-17-2023, 09:26 AM
scarlettotara scarlettotara is offline
Even though the plug ins are "greyed out" you can still use them. It's just the unhelpful colour scheme.
  #28
Old 01-26-2023, 08:59 PM
terracestudio terracestudio is offline
I have the same problem.
  #29
Old 04-04-2024, 09:38 AM
rpmarr rpmarr is offline
Originally Posted by [email protected] View Post
Found this with the update 2022.7. I am running HDX with Catalina. Found if I disable hybrid mode everything works fine.
hi
I have Apple 2019 Mac Pro 3.5GHz 8-Core Xeon W 96GB RAM Catalina 10.15.7 running 2023.3 HDX this work great !!!
I try 2023.6 but had drive nightmare keep crashing ran fine for a day with 2023.3 Drivers Thank You
Audio handles on AudioSuite render get greyed out! Spyderrp7 Windows 2 10-23-2018 08:59 AM
SSL & API plugins greyed out nickremmert 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 12-25-2010 08:02 PM
Audiosuite Process "greyed Out" remute Pro Tools M-Powered (Win) 3 09-24-2006 12:42 AM
audiosuite plugins prs24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-30-2003 02:11 AM
Audiosuite plugins in HD waves3 Pro Tools TDM Systems (Mac) 5 03-29-2002 12:27 AM
