Old 06-08-2020, 09:10 AM
diane_son diane_son is offline
Default Shift Click on timeline open manyyy plug in windows
Hi everyone, I have an issue with plug in windows that I don't think has been adressed here :
My preferences are :
‘open plug in when editing’ on Plug-in, pan and sends,
‘attention most recently clicked daw area’ from track name, edit window, fader, plug in, pan controls, sends
‘open windows on workstation when knobs assigned’ : 1st expand knob module
‘1st expand knob module’ Primary function : EQ
When I click on a track or on the timeline in the edit window while pressing Shift (selection of multiple tracks for example), a window of the plug in that is supposed to be recalled (primary function : EQ) opens.
It behaves the same way as clicking+shift on a plug-in : it opens the plug-in untargeted at the upper left corner of the screen.
It is very annoying since you have to manually close it with the mouse and sometimes it even opens much more than one window if you selected multiple tracks !!
Could you please help?
S6 M40 WS 2020.5 PT2020.5 OSX10.15.3
Thank you!
Old 06-09-2020, 07:02 AM
bucha bucha is offline
Default Re: Shift Click on timeline open manyyy plug in windows
A very old request …
It's been here since we bought our first S6 in 2017.
Thanks for asking Diane.
Old 06-16-2020, 01:14 PM
creativecontrol's Avatar
Greetings,
My initial recommendation, without digging in further, would be to disable Open Windows on Workstation Attention, which can be found under Settings>User>Workstation.
With this enabled (especially since you have Edit Window enabled as a trigger) clicking around is going to constantly trigger windowing interactions vs implicitly clicking on a Send, Plug-In, Pan, etc.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-30-2020, 10:22 AM
Hi Jeff,
well I understand that what's causing the bug but I love this function and it works fine, it just creates an annoying bug. I would love to use it without any problem...
Old 06-30-2020, 01:39 PM
So just to be clear, your use case is such that you are either clicking on the edit timeline or using the p ; nudge track shortcuts and want a window to always pop-up on attention vs explicitly clicking on a pan, send or plug-in in Pro Tools?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-03-2020, 08:10 AM
Hi Jeff,
Yes exactly,
we switch a lot from the S6 and the keyboard and would like to easily edit the timeline and the plug in automation without opening manually an insert. we only use the open plug-in window (no sends or pan).
we love that the window always pop up on attention from the surface or the keyboard, the only little thing is that every time we hit shift, it opens plug in windows that are annoying to close and it opens often during the day!
Old 07-03-2020, 08:20 AM
its2loud its2loud is offline
Originally Posted by diane_son View Post
Hi Jeff,
Yes exactly,
I have to agree and have a similar workflow. The bug is a PITA. I’ve found that if you slow down the Shift + Selection it doesn’t occur as often.
Old 07-14-2020, 07:20 PM
I'll make sure to bring it up with Eddie and crew when he gets back.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Shift click and Cmd click stopped working PT 2019.10 jane90 Pro Tools 2019 1 02-10-2020 07:48 AM
Track commit bug (misnamed files and timeline shift) Poparad Pro Tools 12 5 01-06-2016 07:37 PM
D'oh. It took me 3 years to realize holding shift allows you multiple plug-in windows fenderrocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 08-17-2009 07:03 AM
Explanation for FORMANT shift in Time Shift Plug In, please! Darney 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-13-2007 11:00 AM
Multiple plug in windows open stevejones 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-22-2006 05:08 AM
