Old 02-03-2022, 07:51 AM
creativecontrol's Avatar
Default Re: S6 Scroll PT To Attentioned Track
Adding Eddie.
It sounds like you are pointing to a different interaction that is not really defined. Bank to Attentioned - does just as it says - it banks. Shift + Control while touching a track from a strip on the console would only move Pro Tools Mix or Edit Windows into a justified state.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-03-2022, 01:31 PM
stefanboman stefanboman is offline
Sorry if I’m unclear.
But with the settings described earlier in the thread this occurs for me.
If I attention a track on the tracks page it now scrolls PT to that track.
So far so good, but with these settings the console banks the console if I click the track header in PT(even thou I have auto-banking set to off)
Hasn’t done that before I changed these settings.
Was also hoping for a way to have PT scroll to that track without have to use the two modifiers.
Ideally(for me) would be to have PT scroll to follow the attention button pressed on the fader module.
But if that’s not possible I’d settle for PT scrolling that follows the attention selection thru the tracks page.
My issue is that I can’t seem to find why console banking also goes active as soon as I get PT scrolling working.
Not sure what setting I’m missing.
Stefan Boman
Atlantis Studios-Stockholm
www.parkstudios.se
stefan[at]atlantisstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 02-04-2022, 08:05 AM
EddieJones's Avatar
We need a PT scroll to selected setting in PT. Its on the list.
Old 02-03-2023, 09:02 AM
Ducducgoose Ducducgoose is offline
Hello, Just wondered if there was any update on this?
Old 02-03-2023, 09:04 AM
EddieJones's Avatar
Yes it was added last year into PT
  #16
Old 02-03-2023, 09:05 AM
EddieJones's Avatar
  #17
Old 02-06-2023, 01:35 PM
lucienpalmer lucienpalmer is offline
Is there any conflicting preference that might not make this behavior not work?
I ticked the 'select' box next to 'edit window follows', but when I push the select button or attention button of the channel strip, neither will scroll the edit window in PT to that track. The select button just highlights the track name in the PT GUI.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
  #18
Old 02-07-2023, 05:03 AM
Greetings,
I demonstrated some of these navigation functions in this video / post:
https://duc.avid.com/showpost.php?p=...&postcount=193
Let me know if this helps else we can dig in further.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #19
Old 02-07-2023, 08:09 AM
best,
Jeff
Thanks, Jeff. Great video as always. I'm going to record a quick video of what I'm seeing here and PM you. Thanks!
  #20
Old 02-07-2023, 08:14 AM
EddieJones's Avatar
It might be good to get your session with the S6 settings in it as we tested here and it works OK.
Workstation follows most recently attentioned track GCScott Avid S4/S6 7 06-17-2020 12:08 PM
Auto-Bank to Attentioned Track for Fader Attention Button skilletaudio Avid S4/S6 0 10-21-2019 12:36 PM
Track scroll pasanta Pro Tools 11 5 10-07-2015 09:51 AM
Can there be more than one Attentioned Track? Picture Start Artist Series 2 01-15-2011 02:40 PM
C24 to scroll through a track ianmiller ICON & C|24 3 03-13-2004 09:41 AM
