Old 02-03-2021, 07:44 AM
GCScott GCScott is offline
Default Master Meter Module and PEC / DIR
Is anyone having joy/issues with the PEC/DIR master display combination? We have it working but only under specific circumstances.
It may be worth mentioning we have tried 'Enable Off-Disk only(PEC) Meters for Post Module Assignments' both on and off - (restarting PT in between). Also, we're 2020.11.1 on the s6 and PT 2020.12
We operate with playback machines and a split recorder. The meters seem to dance (not matching) when using DIR as an output from our playback machine and PEC as our recorder stem. The only way we can get around this is by creating an additional 'bus' aux on the recorder that always picks up input from our playback rigs.
Secondly, the meters don't update when in destructive punch record - is this correct? You have to hit 'stop' for the audio to punch and therefore the audio/meters to update.
Old 02-03-2021, 11:34 AM
creativecontrol's Avatar
Default Re: Master Meter Module and PEC / DIR
Greetings,
A few items off top of my head. You should be using the same meter mode / preset in Pro Tools for all machines - sources and recorder. If you are using Linear (Extended) on the Sources also use that on the recorder.
Also - do you have Pre-Fader meters enabled?
Options > Pre-Fader Metering
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-03-2021, 11:39 AM
Hi Jeff! Thanks for replying.
Can confirm all the above are as advised. We do have pre fader metering on by default but have the same issue with it off.
Old 02-03-2021, 01:48 PM
Understood. So for the DIR meters you are assigning from the source WS sessions, you are are targeting your multichannel AUX submaster tracks, yes?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-03-2021, 02:39 PM
Yes that's correct.
Old 02-03-2021, 04:26 PM
Thanks. Let me chat with engineering as I am not seeing that behavior here on my system. Feel free to PM me with any additional details.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Fader Module meter led display with 5.1 tracks o-matic Avid S4/S6 13 08-27-2021 08:17 AM
Master module Appset blank Mishabou Avid S4/S6 9 04-04-2020 06:43 PM
Mono channel meter level lower than Master’s meter level Armando Pro Tools TDM Systems (Mac) 3 07-07-2019 04:51 PM
Master Module Won't Boot hixonjames Avid S4/S6 6 02-09-2018 12:01 PM
Master Module FAN NOISE rcutz Avid S4/S6 11 07-29-2015 06:39 AM
