Old 08-25-2021, 09:37 AM
DAPG DAPG is offline
Default Question about multichannel plugins
I am having an issue when controlling a 5.1 plugin, like McDSP SA-2, that has a GUI that only displays one channel at a time. If I want to look at what the center channel is doing in the GUI and then I touch a knob to control it on the S6, the GUI switches to view the left channel. Is there a way for the GUI to stick to the center channel? It's a problem I run into with several mutichannel plugins.
Any help would be appreciated.
Roy Machado
Dallas Audio Post
Old 08-25-2021, 11:29 AM
creativecontrol's Avatar
Default Re: Question about multichannel plugins
Greetings,
I believe you are in fact inquiring about multi-mono workflows - not multichannel, yes? SA-2 is not offered in a multichannel version.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-25-2021, 12:04 PM
Hi Jeff,
Yes, I guess I mean multi mono. Is there a way to deal with my issue? Any help would be greatly appreciated.
Roy Machado
Dallas Audio Post
Old 08-25-2021, 12:42 PM
its2loud its2loud is offline
What happens when you unlink the channels in the plug-in?
Since your Dialog is usually mostly center channel I would think you do not want that plug-in processing LRLsRsLFE as well.
I often work in unlinked mode with the other channels bypassed in multi-mono mode.
Old 08-25-2021, 12:45 PM
If I unlink the channels, I still have the same issue. I touch the knobs to control the center channel of the plugin and the GUI switches to view the left channel.
Roy Machado
Dallas Audio Post
Old 08-25-2021, 12:59 PM
Yep.
I'm seeing that behavior here as well. It's not just with SA2. Same thing happens with the stock Avid EQ3 mult-mono as well.
This is on all latest EuControl software and Pro Tools.
The workaround is a bit funky but it seems to be working.
1. Unlink all channels in the plugin.
2. Bypass the channels you don't want to be effected by any signal
3. Change the view to C channel in the GUI
4. Check the center square in the channel map as shown in picture. Screen Shot 2021-08-25 at 1.13.46 PM.png
5. Then click on the Left square in the channel map, essentially linking these two parameters together. The square will have a yellow (or whiteish) border showing it's now linked to the center channel. ( see second pic)Screen Shot 2021-08-25 at 1.18.05 PM.png
6. Close the plugin window.
7. Recall the plugin from the surface and adjust a parameter. It will adjust the LEFT channel but the Center channel will follow and since all the other channels are bypassed, your changes will not affect those channels
**One note, be sure to disable BYPASS from the automation parameters. Otherwise this may mess with your settings if you're automating it.**
Old 08-25-2021, 01:47 PM
This is either a bug or a limitation. If you have unlinked and targeted a specific leg (C for example) you should be able to start grabbing encoders and operating on C while the system keeps you on C.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-25-2021, 01:49 PM
Jeff
I think it's a bug Jeff. I'll let Eddie know or he might see it on here. I'm sure you can pass it along as well.
Thanks!
Old 08-25-2021, 05:55 PM
Thanks to Its2Loud for confirming this is a bug. I thought I was doing something wrong. Definitely a workflow killer for me.
Roy Machado
Dallas Audio Post
Old 08-26-2021, 08:31 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Is our bug number PT-268692
Its a hard one to fix but I'm trying to get it in this year. Its been this way forever.
Routing Multichannel Reverb Plugins nickdesigner VENUE Live Sound Systems 3 10-21-2015 04:52 AM
Multichannel Workflow question laki Post - Surround - Video 14 07-15-2011 04:01 PM
PTLE8 will not show some of the multichannel plugins ... Vadadi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-06-2009 10:47 AM
Multichannel plugins (eg DR-008) SupMe Pro Tools M-Powered (Win) 1 04-29-2005 10:32 AM
question about multichannel WMA9Pro MGalway Pro Tools TDM Systems (Win) 9 05-12-2004 08:08 AM
