Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 03-15-2024, 08:33 AM
Pro_Tools_User Pro_Tools_User is offline
Default DADman Import Profile
Our studio mac is networked, with multiple users logging in (University students). We want them all to use the same profile which we have copied to their user documents.
I've noticed that users must import the DADman profile each time they log in, even if they save the profile when logging out.
So, I wondered if this was unusual or if the profile should be recalled on login?
I'm also unsure of the difference between Open Profile and Import Profile. Would one option be better than the other when dealing with a multi-user setup like this?
Old 03-15-2024, 03:06 PM
creativecontrol's Avatar
Default Re: DADman Import Profile
Greetings,
If you use File > Import Profile - you can bring in a Monitor Profile which was created on a MTRX device with a serial number different from your existing. If the monitor profile was created on this device - simply use Open Profile. After performing Import Profile, you need to choose your device from the Select Unit pop-up and then tick Enable Monitor, then I would recommend having them perform a File > Save Profile as... with student name and date. As long as DADman > Settings - has Open last profile at Startup ticked, DADman will restore the last saved state.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-19-2024, 05:26 AM
Thanks Jeff. Sounds like Open Profile would be best as we're all using the same MTRX unit. Will give it a try...
Master vs Cue in DADman Monitor Profile Group Mode? ric982 Pro Tools | MTRX & MTRX Studio 7 11-16-2023 05:23 PM
Dadman 5.6.9.1 not loading last saved profile KenSluiter Pro Tools | MTRX & MTRX Studio 9 07-15-2023 01:56 PM
I got a new MTRX Studio and now my DADman doesn't open any profile ursoctba Pro Tools | MTRX & MTRX Studio 2 11-30-2022 04:28 AM
DADman MTRX Monitor profile loading AINSLIE Pro Tools | MTRX & MTRX Studio 9 02-19-2022 03:29 PM
DADman MTRX profile question SomeOtherGuy Pro Tools | MTRX & MTRX Studio 18 07-20-2020 10:26 AM
