Old 05-06-2021, 12:04 PM
JR Fountain JR Fountain is offline
Default DADman question...
Hey there,
New DADman/MTRX Studio user. My monitor profile has 2 sources, system sound via Dante and pro tools via digilink. I have them set to sum. They each work fine independently but when both are engaged I'm getting a strange behaviour. If I play something in Pro Tools and pan it hard left, I'm getting signal out the right too. If I pan to any other speaker in my 7.1.4 setup it's no problem just the left and only when both sources are engaged. It is really puzzling. Any help would be appreciated!
Thx!
J.R.
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
Old 05-06-2021, 12:22 PM
creativecontrol's Avatar
Default Re: DADman question...
Greetings,
Do you have any Fold Down presets engaged by chance?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-06-2021, 02:09 PM
No, I had thought of that too.
I just realized that with the computer source turned all the way down I'm still getting computer signal coming through on the right channel. If I mute it then it goes away.
J.R.
J.R. Fountain
Old 05-06-2021, 03:19 PM
A few things...
Settings > Monitor Profile > Remove Unused Groups (lower left)
File > Save Profile as > Rename it as something
Is your device firmware up to date? It needs to be 1.0.3.2?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-06-2021, 09:35 PM
The remove groups seems to have fixed it. Can you explain what that did?
Also, which firmware are you talking about? There seems to be a few...
Main Board - cpufw: 1.0.1.1, matrix: 1.0.5.2, nios: 1.0.1.2, recovery 1.0.1.1
Thx for your speedy help Jeff!
J.R.
J.R. Fountain
Old 05-07-2021, 04:52 AM
Glad to hear it. If you make changes to your monitor profile - adding sources, outputs, meters, etc -> until you press Remove Unused Groups - all of those previous resources (you may have removed from the monitor) are still part of the monitor mapping. Source -> Add Existing or Output -> Add Existing will show all of the various groups you may have made previously before pressing remove to purge all unnecessary resources.
Yes, it is highly recommended to update your main board cpufw to current which is 1.0.3.2 -> which you can download from your Avid account.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-07-2021, 05:56 AM
Awesome, upgraded the firmware.
While I have you, another question. If DADman loses EUCON connection what is the best way to regain control? I haven't found a reliable solution other than restarting the computer.
Thx,
J.R.
J.R. Fountain
Old 05-07-2021, 06:21 AM
How exactly does this issue manifest? How do you know that DADman has lost communication with EUCON? How is your network setup and do you have multiple networks enabled including Wifi?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-07-2021, 12:30 PM
Not sure yet, haven't paid close enough attention. Quitting PT and DADman, then opening DADman first worked.
Wifi off, two routers, one for EUCON, one for everything else.
J.R. Fountain
Old 05-07-2021, 04:58 PM
BScout BScout is offline
You can always uncheck and recheck Eucon in DADman to restart it's service (without restarting the computer.)
But, honestly, this shouldn't happen.
If you lose control and the assigned tab in Eucontrol goes to only Pro Tools (I have had this happen sometimes) vs Monitor Control locked to DADman and Entire Surface to Pro Tools, you can always close and reopen Eucontrol (quit it and reopen it). That's the only way I've found to be able to reattach DADman to Eucontrol (Eucontrol gets very stubborn and refuses to recognize DADman as an application so there's no way to relock it to Monitor Control.)
DADMan outputs Goombot Pro Tools 7 04-22-2021 08:27 PM
DADman disconnects pkingduk Pro Tools HDX & HD Native Systems (Mac) 12 07-26-2020 04:22 AM
DADman MTRX profile question SomeOtherGuy Pro Tools | MTRX & MTRX Studio 18 07-20-2020 10:26 AM
DADman .dms vs .dmprof file question Rich Breen Avid S4/S6 15 03-16-2020 03:04 PM
DADMan goes wonky Jared_TL Pro Tools HDX & HD Native Systems (Mac) 5 12-29-2019 01:06 PM
