Old 07-31-2022, 06:29 PM
lucienpalmer lucienpalmer is offline
Default Display module - clips in a folder track
Occasionally I like to lock a folder track to the surface just to keep an eye on things and see what’s coming down the line. But the rectangles that represent clips on the tracks in the folder are extremely small if there’s a lot of tracks in the folder. Which of course makes sense, except when tracks are hidden seems like they should be larger to reflect the tracks that aren’t hidden. Is there a way to change the width or ‘resolution’ of the folder track view?
Shown in the photo is my dialog folder with over a dozen tracks, but only three are set to be viewed. In a comparison the test folder next to it only has three tracks total. On the left you can see that the clips are super tiny showing that the hidden tracks are still accounted for.
Pro Tools Ultimate, HDX3 & MTRX + HD MADI
7,1 MacPro, 3.2GHz 16-core, OSX 10.15
S6 M40 48-5, panners, MPM,Dolby Atmos RMU
AJA Kona LHi, Sync HD
www.ToolshedAudioPost.com
www.TheToolshedStudio.com
Certified for Dolby Atmos Home Entertainment
Old 08-01-2022, 05:31 AM
creativecontrol's Avatar
Default Re: Display module - clips in a folder track
Are the extra tracks in question - hidden but not inactive? Also - how do you have the pref set for "Exclude Inactive Tracks" ? Have you tried to look at the Meters & Waveforms view for the folders by chance?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-03-2022, 08:33 AM
Yes, the tracks are hidden and inactive and the pref is set to not show inactive tracks.
Where do I find the meters and waveform view for the folders?
Old 08-03-2022, 09:55 AM
From Settings > User > Display Module > Meters and Waveforms. Here's an example of how these would then look:
https://www.dropbox.com/s/t8omfgb62b...eform.png?dl=0
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-03-2022, 09:36 PM
I see the screenshot mentions routing folders specifically. Do regular folders have the same options? This definitely looks very different from the display Vontrol views am used to.
Old 08-05-2022, 02:43 PM
With that display preset, the bottom half of the view (clip overview) is identical whether Basic Folder or Routing Folder.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Post Display Module setup lucienpalmer Avid S4/S6 5 12-12-2021 01:14 PM
Fader Module meter led display with 5.1 tracks o-matic Avid S4/S6 13 08-27-2021 08:17 AM
Post Module Display Pec/Dir Gregor B. Avid S4/S6 1 03-10-2021 05:04 AM
Changing Display Module Views From the Surface itsmemagic Avid S4/S6 6 10-19-2019 03:49 AM
can't find audio clips original folder mkoplin Pro Tools 10 2 01-26-2014 10:27 AM
