Old 10-11-2016, 11:14 PM
vudoo vudoo is offline
Default S6 incompatible with Rednet /Dante
I'm testing the Focusrite Rednet Dante (Rednet 2, 5 and PCIe card) and came across a compatibility issue that i hope you guys can help me with.
The Rednet interfaces (Rednet 2 and 5) work fine but the PCIe card won't show up in my DAW unless i disconnect the S6. I have tried both the S6's ethernet port 1 to my switch where DHCP is provided by an Airport extreme connected on the same switch or S6's Ethernet port 2 directly to my MacPro Trashcan.
Any suggestions ?
Old 10-12-2016, 10:27 AM
creativecontrol's Avatar
Default Re: S6 incompatible with Rednet /Dante
Greetings,
We have some users internally with Focusrite RedNet PCIe cards running with S6 without any issues. As a matter of fact, I happen to be receiving one of these cards this week so I will be exploring it as well.
Make sure under AudioMIDISetup you setup your card for 32 ins and outs.
What version of Pro Tools, S6 & OSX are you currently on?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-12-2016, 04:39 PM
Thanks for the reply
After further testing, i don't think the S6 is the problem. The DAW i've tested with (cubase, Logic, Live) just don't see the card 99% of the time. Dante and Rednet control sees it, strange. Also it does not appear in the Audio/midi setup. I'm using a Mac Pro cylinder, 10.11.6, S6 v2.2.
I'm testing the Rednet 2, 5 and PCIe...all the interfaces are recognized and working without any problems except for the PCIe.
HDX and Rednet mrtomcat Pro Tools HDX & HD Native Systems (Mac) 8 04-23-2018 10:44 AM
HD Native or Rednet 2 Dantesjuice Pro Tools HDX & HD Native Systems (Mac) 4 10-14-2015 02:42 PM
Anyone here using Rednet? upscaps Pro Tools HDX & HD Native Systems (Mac) 18 06-11-2015 04:19 PM
ProTools 11 w/Rednet VSC? Barlow macOS 3 01-23-2015 03:03 PM
Rednet is officially out! Emcha_audio Pro Tools HDX & HD Native Systems (Mac) 25 03-22-2013 07:04 AM
