Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 10-16-2022, 06:24 PM
Tamer khaled Tamer khaled is offline
Default Sync x not work with mtrx studio
I bought two Pro Tools | MTRX Studio and Pro Tools | Sync X
when try to use VSO variable seed cannot get any effect speed or pitch
i was try with loop sync and world clock and make a firmware update still not work
any advice ?
i was work in my home hd x , avid hd omni and sync hd it working very good
Thanks
Old 10-16-2022, 08:06 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Sync x not work with mtrx studio
Hi, welcome to the community.
Please avoid using special characters for now, the forum software is a bit picky when your post count is low. Likely you do not want your posts going to manual approval. Thank you.
Janne
Old 10-18-2022, 11:45 AM
creativecontrol's Avatar
Greetings,
MTRX family devices can only tolerate a very small deviation in clock speed and are therefore not ideal for extended VSO workflows as compared to HD IO or other such devices.
Best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 10-19-2022, 08:53 AM
LukeHoward LukeHoward is offline
This is new to me, perhaps the MTRX manual and product sheets should be updated? VSO is very useful in workflows where you need to do deal with instruments recorded at slightly different pitches... I never got it working with the MTRX but I assumed that was an issue with Dante not being able to varispeed rather than the MTRX.
https://lukehoward.com/
Old 10-31-2022, 05:35 AM
This has been discussed freely since the release of the first MTRX, which if memory serves, can tolerate around .33 semitones - up or down.
While the HD IO is capable of far greater VSO, the MTRX is an exceptional sounding device - and part of that is due to the clock design chosen - which agreed is rigid. If VSO is still a critical part of your workflow, I would suggest augmenting with another interface for that use case.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-20-2023, 08:26 AM
MPP MPP is offline
Hi Jeff,
we've installed two new MTRX II by our client who needs to use VSO to change the tuning by 8 cents. But when VSO is set to 0.06 semitones or higher, MTRX II goes out of sync (on its wordclock input). When set to 0.05 semitones, the sync locks again.
We've expected 0.08 semitones to work, based on your 0.33 semitones remark.
Is the clock of MTRX II even more rigid than the original MTRX?
Best Regards,
Pavel Kucera
Old 11-20-2023, 08:59 AM
Yes, the MTRX II is even more picky to clock deviation as compared to the original MTRX unit - which did see some component changes over time.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Sync IO into a MTRX Studio IrelandM Pro Tools | Sync X & SYNC HD 11 10-31-2022 05:47 AM
MTRX Studio ADAT sync issues with external Audit ASP880 Mic Pre rknaub Pro Tools | MTRX & MTRX Studio 12 10-13-2022 07:12 AM
Dolby Renderer sync issue with HDX/MTRX Studio remainanon Pro Tools | MTRX & MTRX Studio 7 05-24-2022 02:32 PM
MTRX MTRX Studio Forum Section? off the wall Pro Tools | MTRX & MTRX Studio 2 05-08-2022 03:20 PM
MTRX-Studio activation card # won't work. How do I get EuControl? DeadlyMixProd Avid S1, S3, Dock and Control App 2 12-29-2021 05:29 PM
