#31
You need to change nothing in your DADman monitor profile.
For your setup you should create a 2x INPUT paths in IO Setup which leverage AUX IO from Pro Tools Audio Bridge 32: Speakers_9 = 7.1.2 path, to accommodate the 9 floor speaker channels + LFE Speakers_Z = QUAD path, to accommodate the 4 height speaker channels Outputs - same as above - but feeding out the MTRX / DigiLink outputs (to DADman) channels 1-14. Yes, you will be able to do Speakers, Dolby Binaural and Apple Spatial all at the same time. Use a 7.1.4 Re-Render as shown in the screen grab to feed into Logic. DAPS Input = Dolby Audio Bridge DAPS Output = Pro Tools Audio Bridge 32 PT Output = MTRX / DigiLink PT Monitor Input = Pro Tools Audio Bridge Once we get wider busses in Pro Tools you won't need to make 2 paths = floor, ceilings. Jeff |
#32
![]() Quote:
![]() Thanx Jeff, as always
![]() Mac Studio Ultra, 64GB, 2TB, OS 12.6, MTRX Studio, PT Ultimate 22.9, HDX1, Sync HD, BM Decklink Extreme 4K, Dolby Atmos PS, Avid Dock, S1, C|8 |
#33
Thank you!!
~Will |
#34
I'm trying a super-simple setup before tackling DAPS, just a two channel PTAB device into Ableton. When the output is a CoreAudio device* that is also clocked by my MTRX, I am hearing the occasional glitch. When the output device is PTAB routed back into PT, seems more solid. But that means having to route everything back through PT for monitoring which I'd rather avoid if possible (but if necessary, so be it).
Early days though, will continue to test! * MOTU M64, USB to MADI interface
https://lukehoward.com/ |
#35
OK, it looks like DAPS doesn't cope so well with DAB or PTAB as input and a (locked) interface as output.
Limiting number of real-time threads in Playback Engine helped slightly, but not really. I tried both with a MOTU M64 and Dante Virtual Soundcard as output devices. I guess the alternative, having a bunch of hidden tracks in Pro Tools to route back through HDX is also fine. (Or there a way to patch this directly within I/O setup?) Renderer logs as follows: Code:
2022-09-30 16:20:29 INFO RendererExecutive - -------------------------------------------------initializing-------------------------------------- 2022-09-30 16:20:29 INFO Scheduler - Running scheduler with #8 threads 2022-09-30 16:20:30 INFO RendererExecutive - Total latency in samples: 1058 2022-09-30 16:20:30 INFO RendererExecutive - Started audio driver with 512 frame size at 48000Hz 2022-09-30 16:20:30 INFO RendererExecutive - ---------------------------------------------------- DONE ----------------------------------------- 2022-09-30 16:20:31 ERROR RendererExecutive - Audio device buffer underrun 2022-09-30 16:20:33 ERROR RendererExecutive - Audio device processor overload 2022-09-30 16:20:33 ERROR RendererExecutive - Audio device buffer overflow 2022-09-30 16:20:35 ERROR RendererExecutive - Audio device processor overload 2022-09-30 16:20:35 ERROR RendererExecutive - Audio device buffer overflow 2022-09-30 16:20:35 ERROR RendererExecutive - Audio device buffer underrun
https://lukehoward.com/ Last edited by LukeHoward; 09-30-2022 at 12:37 AM. |
#36
YES!!!!! Thank you, Jeff. Super excited for this!
Scott Gatteño |
#37
![]() Quote:
Hi Jeff, I trying to follow your instructions here and there is one thing that bugs me: Do I need to create Auxiliary tracks in Pro Tools in order to get the routing from PTAB to HDX/Headphones? If I don't do it, there is no sounds coming from my speakers and headphones! IF I do it, I need to create separate axes for floor speakers, height speakers and for BIN mix on headphones. Only then I can hear something. Also when I was making output paths I chose HDX in AUX I/O in order to get some sounds out of the pro tools and into MTRX/HDX. Also this way there is a big delay from what I see in pro tools and what I hear on speakers and HP's. Am I doing something wrong here?
#38
![]() Quote:
(it would be nice if this could be matrixed in I/O setup, so the monitoring setup is decoupled from the session; maybe it can be and I haven't figured it out yet. This is why I was trying to get DAPS to send straight to the MTRX via another interface such as DVS, but I haven't been able to do that reliably yet.)
#39
What is the benefit of having the monitors returning into Pro Tools rather than just returning them to DADman?
littledevilstudios.com.au Pro Tools Ultimate 2022.7. OSX 12.5.1 HDN. DAD DX-32R. DADman 5.3.4.2. Mac Pro iMac Pro. 10 Core 3.0gHz. 64Gb. BM Decklink. Sync HD. Dolby Mastering Suite 3.7.2. |
#40
None I can think of, except that so far it seems more likely to actually work (based on my limited testing).
Dolby Renderer sync issue with HDX/MTRX Studio | remainanon | Pro Tools | MTRX & MTRX Studio | 7 | 05-24-2022 03:32 PM |
MTRX Studio HDX and Dolby Atmos Production Suite | Goombot | Pro Tools | MTRX & MTRX Studio | 64 | 09-30-2021 02:02 AM |
What brings Dolby Audio Bridge to HDX users? | nedd | Post - Surround - Video | 29 | 01-03-2020 04:24 PM |
Dolby Audio Bridge and AVB | RSLAMBERT | Avid S1, S3, Dock and Control App | 0 | 11-03-2019 02:46 PM |
Dolby Media Producer Suite v2, Decoder, How to get audio to my SPK w HDX and MTRX rig | bsteeve | Post - Surround - Video | 3 | 08-16-2019 07:19 AM |
