Old 06-13-2022, 02:10 PM
JasonRostko JasonRostko is offline
Default Avid HDX Not Showing Up in Sys Prefs or Audio Midi Set-up
Building out a new room and for some reason the HDX card is read and works fine when using Pro Tools, however, when I quit out of Pro Tools, the HDX card does not show up in my Sound System Preferences nor the Audio Midi Set-Up. I've Googled but haven't found a solution.
System Notes:
2022 iMac, Monterey 12.1
Pro Tools Ultimate 2021.21
HD Driver 2022.5
Apogee Symphony MKII connected to Sonnet Chasis which connects to iMac via TB 3
Can anyone assist?
Old 06-13-2022, 02:56 PM
Default Re: Avid HDX Not Showing Up in Sys Prefs or Audio Midi Set-up
And the problem can only be the core Audio driver is not installed and working correctly, maybe it's not been granted security permissions.
Remember Pro Tools does not use CoreAudio to access HDX/HDN cards which is why that works.
Try uninstalling and reinstalling it. Pay attention to make sure you approve the install in Security & Privacy Preferences. Pretty sure you'll find lot so discussion on these driver installs if you search for it.
Old 06-14-2022, 09:47 AM
i was aware of the security permissions upon initial install but tried again and its the same issue. The PCI information in system information says it's installed and being read, too.
Any other ideas?
Old 06-14-2022, 12:05 PM
BScout BScout is offline
AvidAudioServer is the process that makes that possible. It is either not running or being blocked by the system. It's located in
Applications > Avid > AvidAudioServer
folder.
Old 06-15-2022, 08:37 AM
creativecontrol's Avatar
Believe it or not - we've also seen ZOOM steal the AAS - Core Audio driver. Try uninstalling Zoom and see if that helps.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-16-2022, 06:58 AM
folder.
attached is what the audio server looks like, seems pretty normal to me. note though that i have to use the AvidAudioServerLauncher not the AvidAudioServer
File Type: jpg Screen Shot 2022-06-16 at 9.42.58 AM.jpg (39.2 KB, 0 views)
File Type: jpg Screen Shot 2022-06-16 at 9.43.07 AM.jpg (40.5 KB, 0 views)
Old 06-16-2022, 12:38 PM
Though there is configuration inside it, the point is it also runs a background process.
That background process is what puts CoreAudio driver in Audio MIDI Setup for Avid HDX/Native. If you kill it (or disable it), there will be no CoreAudio for HDX/Native.
Old 12-01-2022, 02:57 AM
asef@me.com's Avatar
[email protected] asef@me.com is offline
Hello mate
I have the exact same problem. Did find any solution to bring back the HD Native card in midi setup or audio in/out devices?
Protools 11 HD,HD Native card, Icon D-Command, Omni, Sync IO, Symphony 6.5, Mac Pro
Old 03-04-2023, 10:29 AM
PT_NOOB_CH PT_NOOB_CH is offline
I have this problem with my HDX card as well (doesn't show up in system prefs or audio/midi setup) - PLEASE HELP!
Old 03-08-2023, 02:58 PM
i ended up having to get a new HDX Sonnet Chassis. That was the only thing that worked
HD I/O's stopped showing in Avid Audio server, no longer track into Logic Oscillaterecordings Pro Tools HDX & HD Native Systems (Mac) 0 03-17-2022 08:26 AM
Workspace advanced search prefs not showing in window configurations Wasaia Pro Tools 11 0 02-26-2015 02:44 AM
Deleted PT Prefs now 3rd Party RTAS aren't showing up imdrecordings Windows 0 10-04-2011 07:42 PM
Midi Devices not showing up after setting up Audio Midi Setu nick535nak Pro Tools TDM Systems (Mac) 4 09-23-2007 01:15 AM
MIDI I/O not showing up in Audio Midi Setup SMSanchez Pro Tools TDM Systems (Mac) 3 11-11-2005 09:25 AM
