Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 03-20-2024, 02:50 AM
foret_sombre foret_sombre is offline
Default DADman channel selection
Is there a way to solo one monitoring channel on the DADman ?
In 5.1 I can easily mute the four channels I don't want, but with 20+ channels it gets tedious.
Old 03-20-2024, 04:29 AM
creativecontrol's Avatar
Default Re: DADman channel selection
Greetings,
Software only DADman or do you have a EUCON, MOM or Streamdeck possibility as well?
If software only, use the Settings > Monitor Profile > Fold down - to facilitate quickly soloing common groups of speakers (elevation, quad, etc.)
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-20-2024, 08:18 AM
Thanks for your answer.
I need it to work with a S6 master module.
Old 03-20-2024, 08:49 AM
This is what I would do.
https://www.dropbox.com/scl/fi/305rx...pze8qkzpr&dl=0
Access Control Room from the lower right quadrant Soft Keys on the Automation Module.
Press Spkrs
Press Spkrs+
Press Sum - this then turns into InterCancel
Push for the Speaker you want to isolate.
Push InterCancel to go back to Sum
Push All On to turn all of the speakers back on.
If you simply want to quickly isolate common sets of speakers - use the Fold down preset tip as well.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
EQ turns off Left, Right and Centre Channel on Dadman Syncbox Post Pro Tools | MTRX & MTRX Studio 10 12-02-2022 10:39 AM
Setting to make plugin selection in DAW follow channel selection? polyh3dron Avid S4/S6 16 08-23-2021 09:23 PM
MC Mix/Control- Channel and fader selection postprosound Artist Series 1 02-14-2012 09:35 PM
noinput is the only selection in the channel input Marty_DD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-12-2005 05:45 PM
noinput is the only selection in the channel input Marty_DD Pro Tools TDM Systems (Mac) 2 11-09-2005 05:08 PM
