Old 04-02-2022, 03:47 PM
Mishabou Mishabou is offline
Default Master Module Version Mismatch
I'm getting a Master Module Version Mismatch error after installing 2020.11, did a search and apparently there's a bug with this installer but the link for the solution is no longer working.
Old 04-03-2022, 03:33 PM
creativecontrol's Avatar
Default Re: Master Module Version Mismatch
I would not recommend running 2021.10. I would check to make sure that both the MTM and the workstation are running build 29 of 2021.10.1.
If you are still having troubles, uninstall the MTM software and reinstall x29. Uninstall the unified EUCON client (install then tick uninstall + prefs), then reinstall and tick S4 S6.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Version Mismatch error with EUCON 2021.6 and Avid Control Babylonians Artist Series 2 06-30-2021 06:01 PM
iPad Control just changed to Version Mismatch smallstonefan Avid S1, S3, Dock and Control App 7 11-27-2020 07:00 AM
Win 10 Version Mismatch noiseboyuk Avid S1, S3, Dock and Control App 3 05-06-2020 05:20 AM
Version mismatch error loud neighbor Avid S1, S3, Dock and Control App 3 12-19-2019 09:23 PM
Master Module FAN NOISE rcutz Avid S4/S6 11 07-29-2015 06:39 AM
