Do To Selected not doing to selection!
Understood. Currently the best workflow for that is probably to use the Groups access from the Master Module right (default soft keys) and use Modify Group then push the group name. Obviously this would require GUI interaction from there on so you are probably saying why not just do it all from the GUI? :)
Jeff |
Re: Do To Selected not doing to selection!
This is why I suggested earlier in the thread that if you are viewing the Track Matrix and selected a VCA group, if there was an Add/Remove button after Assign, you would press that and having selected a VCA, you would simply hit Select on a channel to add or remove it from the Group.
Dave Marsden UK |
Edit Selection Follows Clip List Selection not working | Sjoberg | Pro Tools 10 | 3 | 12-04-2020 12:38 PM |
Move the selection forward by the selection amount not working in PT10 [SOLVED] | Captain Audio | Pro Tools 10 | 3 | 06-17-2014 10:43 AM |
Playing back part of a selection without affecting timeline/selection | jschmidtiii | macOS | 2 | 05-11-2013 01:05 PM |
blank selection: no audio was selected | Felix Rost | macOS | 3 | 01-24-2013 12:42 PM |
Can a selected region be De-selected using MC Control | propower | Artist Series | 0 | 11-08-2011 11:34 AM |
