Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 11-14-2022, 12:36 PM
IndreStudios IndreStudios is offline
Default Sync I/O (original blue) as standalone generator?
I have an older blue Sync i/o that I was hoping to use as a standalone timecode generator. I am able to access all functions, except for the option to change the "clock reference". The button doesn't currently change anything, and it's stuck on "loop sync". I'm guessing I need to be set to "internal", just can't get there.
When set to "Generate" and pressing "Run" nothing happens.
Tried doing a factory reset, same thing. Any insight would be appreciated.
Michael Comstock
Indre Recording and Production, Philadelphia
www.indre.com
Old 11-23-2022, 08:38 AM
creativecontrol's Avatar
Default Re: Sync I/O (original blue) as standalone generator?
Greetings,
Check out the SYNC IO guide here -> pg.57 where the Front Panel parameter controls are described:
http://akmedia.digidesign.com/suppor...v111_25667.pdf
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
AJA-GEN10 Trilevel HD and SD Sync generator TVPostSound Buy & Sell 5 10-12-2014 02:54 PM
Sync-blue and midi-blue with protools 11? John Becool Pro Tools 11 4 09-11-2013 10:28 AM
Original Mbox Standalone Driver for Windows 7 Kudy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 04-23-2013 05:43 PM
Original MBox - Standalone Driver for Windows 7 toastyt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-06-2010 12:52 PM
Original M-Box as a standalone mic preamp beyondat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-02-2008 10:11 PM
