Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 11-09-2022, 04:30 PM
stevenculp stevenculp is offline
Default Sync HD won't generate LTC
Hi all,
I tried connecting a Sync HD to our MacPro HDX rig running PT12 and can't get the Sync hd to generate LTC. Session setup in PT sees the Sync HD and I get the control panel, but generate doesn't appear as an option in the Positional reference drop down.
If I uncheck enable sync device in the session setup window, and manually set the Sync HD to generate LTC using the front panel, the generate led goes out when i re-enable the control from session setup.
Could this be a firmware conflict? The Avid site says it should be compatible...
Any help is greatly appreciated.
Thanks!
Old 11-09-2022, 05:38 PM
its2loud its2loud is offline
Default Re: Sync HD won't generate LTC
I have so many questions but my main question wound be…
Do you have a video reference signal hooked up to the Sync HD vid ref input?
My second question is about this
“but generate doesn't appear as an option in the Positional reference drop down.”
Drop down? To generate LTC in Pro Tools you have to turn on the Gen LTC button located in the expanded transport window at the top of the session.
Old 11-10-2022, 09:44 AM
creativecontrol's Avatar
Indeed. The LTC button accessible from the Synchronization toolbar in the Pro Tools Edit Window should be lit. See attached where it is not enabled:
https://www.dropbox.com/s/3txih2dzyd...C_Tab.png?dl=0
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-10-2022, 12:08 PM
Yep it was the secret hidden button in the transport window.
Thanks!
SYNC HD and BITC generate MIKEROPHONICS Post - Surround - Video 32 02-28-2014 06:28 AM
AVID Sync HD won't generate 23.976 LTC jim33 Pro Tools TDM Systems (Mac) 1 01-20-2012 10:20 AM
Sync I/O smpte generate??????? ev33 Pro Tools TDM Systems (Mac) 3 02-11-2009 05:49 PM
SYNC I/O won't generate MTC from PT Matthew Steel Pro Tools TDM Systems (Mac) 2 01-10-2005 06:11 AM
PT can generate MTC.. but can it sync to it> FineTuneMX Pro Tools TDM Systems (Mac) 4 07-15-2004 05:11 AM
