Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 03-22-2022, 07:49 AM
EddieJones's Avatar
Default Re: Eucon 2021.10 Unable to Install Mac M1 Monterey
Can you take a video of you installing it from start to the error?
Old 03-23-2022, 12:23 PM
juanpiedra014 juanpiedra014 is offline
Just tried this. No success
Old 03-23-2022, 02:29 PM
creativecontrol's Avatar
You were unable to capture a screen video grab of the installation process?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-24-2022, 06:52 AM
Sorry guys, here it is:
https://www.dropbox.com/s/hig3j1b6jx...%20AM.mov?dl=0
This was in the new admin user.
Old 03-25-2022, 09:10 AM
EddieJones's Avatar
You are the only person out of thousands seeing this, so it has to be something local. Have you redownloaded the installer, do you have a virus checker enabled?
Old 04-03-2022, 03:07 PM
I don't. My mac was migrated from an older mac, maybe some third party applications can be interfering? I had an old Eucon running and it worked when migrated but I erased it because Artist Mix didn't showed up names on the screen. But it runned. I erased it so I can upgrade it and boom, now I can't install even that old Eucon
Old 04-03-2022, 05:03 PM
I also tried redownloading installer several times. No antivirus on.
Old 06-15-2022, 02:49 AM
alexathelm alexathelm is offline
I'm having the exact same issue. Would really appreciate some help from Avid
Old 10-10-2022, 12:45 PM
Robmanzzz Robmanzzz is offline
Have any of you ever resolved this issue?
I too have recently migrated, from a Mac Pro 5,1 to a Mac Studio M1 Max. Same problem: migrated using Migration Assistant: everything worked fine. I wanted to add the XMon application and ran the installer. Got the error and BOOM, gone where all EUCON applications. Tried giving Installer Full Disk Access, removing prefs in Application Support, Repairing Permissions in Terminal. Nothing works.
Old 10-10-2022, 01:08 PM
JFreak JFreak is online now
This is something I don't hear often usually recommended to NOT use Migration Assasin
2021.12 / Izotope RX / Monterey Pete Gates Pro Tools 9 03-17-2022 11:01 AM
Protools 2021.3.1 compatibility with Monterey alfiea Pro Tools 7 02-06-2022 01:02 PM
PT 2021.10 - Monterey - M1 Max - EuCon - Joy teedeecee Avid S1, S3, Dock and Control App 3 12-09-2021 03:46 PM
PT 2021.10 - Monterey - M1 Max - Insane teedeecee Pro Tools 12 12-09-2021 04:34 AM
Has anyone tried Pro Tools 2021.7 on the Monterey Betas? off the wall macOS 28 11-17-2021 10:21 AM
