Old 11-06-2021, 11:25 AM
ScottyD ScottyD is offline
Default Moving from XMON / S6 to MTRX... Talkback mic question
Going from an S6 / XMON setup and migrating to a MTRX, what is the best method to hook up a talkback mic for the S6 into the MTRX? The XMON had TB input. MTRX doesn't appear to work in the same manner. Hindsight 20/20 I didn't provision for a Mic Pre A/D card for the MTRX. So I think the 2nd best option might be to use an external mic pre in-line between the mic and an available line input on the MTRX. Would that make sense? Or is there a different option?
TIA,
Scotty
Old 11-06-2021, 12:31 PM
BScout BScout is offline
Default Re: Moving from XMON / S6 to MTRX... Talkback mic question
This. With a dynamic mic it doesn't need much and you just define what is the input line for TB is in DADman.
We use a cheap MOTU (that is attached to the mix computer for system sounds.) 6 channels are 5.1 defined as a input for computer system sounds in DADman. 1 channel is a pass through of the MOTU mic pre for TB. The MOTU goes out analogue to a MADI D/A A/D (SPL Madison) that is hooked to the MTRX Madi input. So none of the MTRX analogue I/O is used.
Old 11-08-2021, 09:20 AM
creativecontrol's Avatar
Yes, indeed, the Settings > Monitor Profile > Talkback assignment can be anything analog or digital which is populated into the MTRX frame. Here's one of many other options that would work for this by leveraging a Dante based Mic pre ->
https://studio-tech.com/products/m5205/
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Mtrx talkback latch and momentary Markk Pro Tools | MTRX & MTRX Studio 21 12-19-2023 06:56 PM
S6 Talkback>MTRX>Source connect DHS Avid S4/S6 1 11-25-2019 04:08 PM
Monitor Knob - Cut Assignment like XMON but now for MTRX innenhofstudios Avid S4/S6 10 05-17-2018 03:23 AM
Xmon, listen mic and talkback amolin Avid S4/S6 13 06-16-2016 07:22 PM
System 5MC and XMON Talkback Mic Help Bear Jam System 5 6 11-30-2012 10:15 AM
