Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 11-15-2021, 07:57 PM
Jeff Schmidt Jeff Schmidt is offline
Default MTRX Sample Rate Change = Click click Click Crash
I routinely need to move between sessions at different sample rates and I/O settings.
EVERY time I switch SR - MTRX goes through a series of clicks and clacks while PT holds and Mac presents the technicolor spinning pizza wheel of death for up to 30 seconds. After which I can sometimes continue to work - but many times Pro Tools simply crashes and requires a restart.
MTRX is the clock lead for everything else.
Is there another way to change sample rates for this device that prevents this ridiculous song and dance? No other interface I've ever owned has ever had such drama changing SR. Seems really off for such an expensive piece of kit.
2019 Mac Pro 7,1
192 GB RAM
Catalina OS 10.15.7
PT Ultimate, or whatever 2022.6 is called now
HDX 2 w MTRX, Dadman
9.1.4 Dolby Atmos over Dante to external RMU
Old 11-15-2021, 08:28 PM
BScout BScout is offline
Default Re: MTRX Sample Rate Change = Click click Click Crash
It’s been in the install notes.
Disable the Avid Audio Server (what presents HDX hardware as core audio to macOS). Just have to change the name of the utility by putting a # before the app name
Old 11-15-2021, 08:59 PM
Great - thank you. I'll give that a try.
Maybe instead of burying this info in "install notes" Avid could engineer the gear to just work? Or maybe not even install Avid Audio Server?
What an utterly ridiculous thing to have to do for a $10k piece of kit.
2019 Mac Pro 7,1
192 GB RAM
Catalina OS 10.15.7
Old 11-16-2021, 05:46 AM
creativecontrol's Avatar
Greetings,
For reference, the Avid Audio Server is only necessary if you need to access the HDX/HDX -> MTRX/ST hardware outside of Pro Tools via CoreAudio. Most users leverage DVS, PCIeR or other devices in lieu of HD + Core Audio since both Pro Tools + another app cannot communicate with the hardware simultaneously. It's simple enough to disable.
Also, especially when using SYNC X or SYNC HD -> MTRX, you can maintain the same clock source when closing Pro Tools or rebooting the workstation.
If AAS is active and there is a disparity between the Sample Rate of Pro Tools and the rate of CoreAudio -> you will see MTRX (Conf) jump to 192k by default when you quit Pro Tools, if Adapt to is set to DigiLink since Core Audio takes over once the hardware is available again.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 11-16-2021, 06:46 AM
MCorbin's Avatar
MCorbin MCorbin is offline
Jeff
Could you let me know a few pieces of information please?
DADMan Version
PT Version
Clock settings for DADMan (Sync Source & Adapt To)
PT clock settings
When you are changing SR, where are you changing it? In Dadman or by creating/opening a new session at a different SR?
Thanks!
m
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 11-16-2021, 10:13 AM
Originally Posted by MCorbin View Post
Jeff
DADMan Version
-> 5.4.5.1 build 1
PT Version
-> PT 2021.6.0
Sync Source (Internal)
Sync Out (Word Clock)
Sync Term (High Z)
Did dly (7)
SR - -> (48khz)
Adapt to (DigiLink 1)
PT clock settings (MTRX)
I've tried both to no effect. I also change it in PT Playback Engine when I know I need to open a session of a different sample rate - that too produces the same click click click stall/crash
Thanks!
m
2019 Mac Pro 7,1
192 GB RAM
Catalina OS 10.15.7
Shift click and Cmd click stopped working PT 2019.10 jane90 Pro Tools 2019 1 02-10-2020 07:48 AM
Avid can you please sort out the click track & Click 2 plugin protoolsuserman Pro Tools 11 14 11-14-2013 08:11 AM
Power Harness, click click click director 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-14-2004 09:50 PM
any way to change click track's "click"? thomsbrain 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-26-2004 05:32 PM
Bounce and sample rate convert caused a strange click! uno1234 Pro Tools TDM Systems (Mac) 0 04-08-2000 08:51 AM
