Solved: MTRX II - Multiple Digilink cards, appear out of order in I/O setup
Is anyone using multiple Digilink expansion cards in a MTRX II and could you confirm if you are experiencing this issue?
In Pro Tools I/O Setup, the interfaces appear in the following order: Digilink Main - Port 1 Digilink Main - Port 2 Digilink Card 2 - Port 1 Digilink Card 2 - Port 2 Digilink Card 1 - Port 1 Digilink Card 1 - Port 2 In DADman, in the Digilink tab, Card 1 and Card 2 are both set to emulate "Digilink Card" on both ports. Changing those to "MTRX 32x32" has no effect. "Digilink Card 1" is in slot 1 of the MTRX II, ""Digilink Card 2" is in slot 2. My HDX 3 system is connected as follows: HDX1 Port 1-2 to Main Port 1-2 HDX2 Port 1-2 to Digilink Card 1 Port 1-2 HDX3 Port 1-2 to Digilink Card 2 Port 1-2 |
Re: MTRX II - Multiple Digilink cards, appear out of order in I/O setup
Greetings,
When looking at the back of the MTRX II device card slots, are you justifying your cards on the far right? best, Jeff |
Yes, Slot 1 is on the right side of the MTRX II when looking at the back
Also, the interfaces are not labelled with consecutive letters, which I do not think I have seen before in Pro Tools.
When selecting "default" in the Output paths tab for I/O Setup, this is the result: A Main: 1-32 C Main: 33-64 E Card 2: 1-32 G Card 2: 1-32 I Card 1: 1-32 K Card 1: 33-64 |
No, I'm not seeing that behavior here on a Mac Studio on macOS 13.x with a Sonnet Echo III, HDX3, MTRX II:
https://www.dropbox.com/scl/fo/f6en2...4ads3tf7y&dl=0 But, yes, the card labels should be as shown in the grabs: A (B) C (D) E (F) G (H) I (J) K (L) best, Jeff |
Doh! User error, of course. I confused the numbering of the digilink cables, which were out of order - not the cards.
Thanks, Jeff, for your quick response. I am using the MTRX II via HDX and thunderbolt with a combination of Dante (to Eventide H9000), AES/EBU (various monitors and digital effects) and 64 analog I/O in DAD units connected via DADlink. This is the most stable, efficient, excellent sounding as well as powerful/configurable/upgradeable system of I/O I have ever used with Pro Tools. Over the years I have used various incarnations of Apogee, Digidesign, Avid, Lavry, and Mytek converters. |
MTRX Monitor Setup - Dante and DigiLink to Same Monitor? | jb_trm | Pro Tools | MTRX & MTRX Studio | 8 | 12-28-2023 08:32 AM |
MTRX Studio Dadman Can't Join Digilink 1 ch. 7-8 to DA | whatfools | Pro Tools | MTRX & MTRX Studio | 3 | 08-03-2023 10:40 AM |
MTRX Studio on TB with DigiLink to interfaces? | Novae Studios | Pro Tools | MTRX & MTRX Studio | 6 | 07-19-2023 02:36 PM |
MTRX DigiLink | corp | Pro Tools | MTRX & MTRX Studio | 4 | 01-21-2021 02:19 PM |
MTRX hookup question, Dante vs Digilink | SomeOtherGuy | Pro Tools | MTRX & MTRX Studio | 26 | 01-03-2019 11:29 AM |
