Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 07-03-2023, 06:49 AM
creativecontrol's Avatar
Default Re: DADman 5.6.9 Now Availible
I believe that is something that NTP engineering would like to realize but is not currently possible.
best,
Jeff
Originally Posted by uptheoctave View Post
Will Dadlink work with MTRX (1) as well as 2?
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-03-2023, 06:52 AM
No firmware update is required for DADman v5.6.9.x. Make sure your MTRX Studio Main Board is running 1.1.1.5 or greater.
best,
Jeff
Originally Posted by IrelandM View Post
Hi everyone,
Is there a firmware update required for use with the MTRX Studio and DADMan 5.6.9.1.
Also could Avid include a release date / time within user's accounts.
Regards
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-04-2023, 03:13 PM
uptheoctave uptheoctave is offline
best,
Jeff
Thanks for the info Jeff.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 07-04-2023, 03:37 PM
BScout BScout is offline
best,
Jeff
Isn't "DADlink" just "NTP Hotlink"? The Penta 720 (which by all appearances is just the AX32) has this feature. The AX32 shows the option for NTP hotlink too (from the beginnings of that unit) for optical MADI. And of course, AX32 and MTRX I are sister products. Would love more insight (possibly from NTP/Jan?) We have a DAD Core256 coming to bolster a completely maxed MTRX I and this would add some more flexibility.
Old 07-07-2023, 06:14 AM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
HotLink only supports 48k sample rate. DADlink supports all sample rates from 44.1 to 384 kHz (with channel count dependant on sample rate).
DADlink also includes timestamps so the outputs from the router in each device can be time-aligned, i.e. the latency in the router is the same no matter whether a channel passes through just one device or through multiple devices (that are linked via DADlink). This means that if you distribute a channel across multiple devices, the output from each device will be aligned (assuming the output is the same type on all devices). This is btw. one of the reasons why DADlink and HotLink are not compatible.
Implementing DADlink on AX32/MTRX I is challenging because the FPGA that would do DADlink is completely full, so our engineers are looking at various possibilities for optimizing it. We will have to wait and see if they succeed with it.
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
  #16
Old 07-07-2023, 06:43 AM
Thanks Jan, that is all very helpful to know.
James Richmond
Affiliate Links:
  #17
Old 07-07-2023, 11:47 AM
This is great to hear. It would help with adding the newer equipment to established DAD/MTRX setups.
(And, as a side note, even if the full channel compliment wasn't possible on the AX32/MTRX, I'd take 1/2 the channels rather than none at all.)
Most of our stuff is 48k (post production) so higher sample rates are less of a worry but that time-alignment/stamping would be really useful for distributed units connected via fibre.
  #18
Old 07-07-2023, 12:00 PM
+1 to this.
I've got 2x 1st gen boxes and I'd rather not sell them if I do not have to.
Really my need is simply serving up the analogue IO to the main interface (MTRX II).
I've tried Dadlink in the last few days and it hasn't gone well, so far.
I might be doing something dumb but it works fine when setting the optical ports to MADI.
When I set them to DADlink the AX64 (which is following the MTRX II) drops sync every3-4 seconds if I use Dadlink as the sync method.
If I use workclock or Dante to sync then the audio is ok but I get the channels flashing yellow red in Dadman.
I've got a support call in so hopefully will get to the bottom of it.
Here is a video showing the issue.
https://www.youtube.com/watch?v=lyuFVjXFZEw
James Richmond
Affiliate Links:
  #19
Old 12-11-2023, 04:26 AM
Just to close the loop on this one, I suspect during this trial you were not using the required Gigabit optical SFPs - which would explain the flashing channels.
One of the 850nm options that works well is the Avago compatible SFP from ProLabs: AFBR-5701PZ.
For more information on DADLink:
https://resources.avid.com/SupportFi...ADI_module.pdf
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
  #20
Old 12-11-2023, 05:05 AM
best,
Jeff
Hi Jeff,
Yes sorry, I covered this off a long time ago.
I should have updated the thread, but I wrote an article about DADlink where I discussed the issue.
https://www.production-expert.com/pr...-count-systems
Yep, it was using the MADI compatible SFP's that I was using previously: Broadcom HFBR-57E0LZ
They won't work with DADlink.
I had some Ubiquiti UF-MM-10G SFP’s lying around so I used a couple of those and they are fine.
I've had no issues.
Given they are rated for 10G they are overkill but, as I said, I had them to hand.
James Richmond
Affiliate Links:
DADman v5.6.5.1 Now Available creativecontrol Pro Tools | MTRX & MTRX Studio 0 12-01-2022 09:00 AM
protools 10 not availible anymore? chalz2502 macOS 2 02-03-2014 01:31 PM
are there any fixed bugfixes f t-racks availible?? gregor rasek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-11-2004 06:39 AM
Shouldn´t be PT LE 6.1 not long since be availible?? clusterer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-15-2003 06:16 AM
Auto-Tune 3 update availible Michael Logue Pro Tools TDM Systems (Mac) 0 10-09-2001 03:27 PM
