Dolby Renderer, HDX, DADMan and Thunderbolt routing
So I've finally gotten into try and re-routing my Atmos template with my Thunderbolt card and I'm just having some issues. My setup is a MTRX2 with the thunderbolt card, HDX2 with a SyncX and the Dolby Renderer on the same machine (7.1.6). Before the thunderbolt card I had the HDX engine selected. I was routing out the Renderer via the Dolby Audio Bride and coming back into ProTools on input via the ProTools Audio Bridge 64. No issues with any of that. Now my main purpose for getting the thunderbolt card was to get as many live re-renders back into protools. I am able to get all my 128 beds and objects to the renderer via the thunderbolt card but I'm having an issue bringing them back into protools and I'm really not sure what I'm doing wrong. I'm almost positive it has to do with routing in the DADMan. Basically every time I am selecting the thunderbolt card for audio input and audio output in the renderer I am getting feedback so obviously I'm feeding the card back into itself. I can't get into the renderer without patching thunderbolt 1-128 into thunderbolt 1-128. That all seems fine, unless I'm doing something wrong but that is the only way I am seeing my beds and objects in the renderer. So coming back from the renderer is the issue. I'm a bit stumped. If I could get a clearer idea of how to route this that would be extremely helpful.
Re: Dolby Renderer, HDX, DADMan and Thunderbolt routing
It’s not like Dante where the same channels #s are two way. |
Are you using the configuration Avid suggests in the second half of the video? https://www.youtube.com/watch?v=EUwp6m2cjOk
It is roughly something like: PROTOOLS -> 128x HDX2 -> DADMAN -> 128x TB3 -> RENDERER -> 128x TB3 -> DADMAN -> 128x HDX2 + MONITOR PROFILES. In DADman, HDX2 outputs should be routed to the corresponding TB3 inputs to get audio into the renderer, and the TB3 outputs from the renderer should be routed to the corresponding HDX2 inputs for your live rerenders. You need to a bit careful of the rerender routing in Pro Tools to ensure it isn't being routed back out of Pro Tools and into the renderer again. Using a NULL bus in Pro Tools can be helpful for this, or outputs that never go to the renderer at all. From there, you can define all manner of monitor profiles. Renderer Atmos output, live re-render downmixes, etc.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
Thanks for posting this. It helped me get over the finish line. The issue I was having was the renderer was constantly feeding back with the thunderbolt selected as input and output. After diving deeper into the renderer there were two things that got changed. I had some leftover routing from by previous Mac Pro Intel and the outputs of the Renderer were not set. Not sure which one was causing the issue but it's now resolved. 128 channels of thunderbolt to the renderer and 128 channels of thunderbolt from the renderer with the HDX playback engine. And although the video was helpful with a lot of pausing and zooming in on DADMan setup I wish there was a bit of a deeper dive in the videos on specific setups and not so much an "all in" video covering all the options of the MTRX2 because there are a million. Either way, things are fully working. Thanks.
G https://www.dropbox.com/s/7q3m4lnr5f...ource.pdf?dl=0
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
G You can download this also: It's a 394mb pdf https://www.dropbox.com/s/7q3m4lnr5f...ource.pdf?dl=0
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Interesting. Yes, very great doc to have. Thanks for posting link.
Yes, indeed. Now that 5.7 is available all of the descriptions to functionality in DADman should be correct. I recently added workflow descriptions for using the Internal Renderer in PT 23.12 with just a laptop or with MTRX Studio for monitoring Apple Spatial in addition to workflows for Omnibus 2 and how and when to use the Adapt to option.
best, Jeff |
(And lt looks like a lot of work to put it together!)
Genlock with HDn and Dolby Renderer | Frank Kruse | Pro Tools HDX & HD Native Systems (Mac) | 9 | 10-06-2023 08:58 AM |
Dolby ATMOS Renderer | KeyplayerG | Post - Surround - Video | 20 | 08-22-2023 08:08 AM |
PT Bounce to ADM vs Dolby Renderer ADM | peapodpost | Pro Tools | 1 | 03-17-2023 10:29 PM |
Dolby Renderer and Big Sur? | LewisP | Pro Tools | 1 | 08-16-2021 07:31 AM |
