Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 02-01-2024, 06:59 PM
briansin briansin is offline
Default Panning mono source to stereo output (not fold down)
I noticed in one of Jeff's videos that one of his mono monitor sources ("LB") had a "center" pan fader on the top of the strip in the monitor profile. I assume this is to pan the mono channel across the stereo monitor output.
I cannot figure out how to get this slider. I have a mono source and it simply pan laws to output to both L and R on the monitor output.
How can I get this panning slider to show up? It would be extremely useful for doing artist mixes.
Thanks!
Brian
Old 02-01-2024, 07:03 PM
creativecontrol's Avatar
Default Re: Panning mono source to stereo output (not fold down)
Greetings,
If the mode is set to Mono for the source input in your monitor you will certainly see a pan slider. The default mode when adding a source is Stereo FYI. Also - make sure your monitor is in SUM mode.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Last edited by creativecontrol; 02-01-2024 at 08:10 PM. Reason: Source Summing Mode was wrong
Old 02-01-2024, 07:53 PM
Thanks Jeff, the mode was the problem. Note that it needs to be in SUM mode to have a panning slider, not switched. but that did it, thanks!
Old 02-01-2024, 08:10 PM
Yes, you are correct -> SUMMED.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Panning - Sending two mono tracks to a stereo bus adam79 Tips & Tricks 5 08-30-2017 06:29 PM
Difference in Bouncing Stereo to Mono and Panning? JLEpperson Pro Tools 10 1 07-10-2012 02:23 PM
Mono source = stereo file? rui_guerreiro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-19-2011 04:35 AM
Stereo AudioSuite on mono source Karl Engel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-12-2006 07:06 AM
Stereo vocals from mono source... Xray55 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-05-2002 03:56 PM
