Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 12-20-2023, 11:31 AM
remainanon remainanon is offline
Default MTRX Studio Wakes up Dead today…*Fairly urgent issue
Title says it all
MTRX can't load the profile/setup and throws an error:
Connection error
Error code: 0x80000001
No changes in the setup. IP addresses look correct in Device list, although if I right click the MTRX and select "NETWORK SETUP" the window appears blank. If I enter the correct IP settings in that window anyway, the unit restarts, then won't connect. It shows correct IP in device list, but right-click menu shows blank, as before.
I'm currently dark until I can resolve this.
Thanks
JW
Old 12-20-2023, 01:59 PM
creativecontrol's Avatar
Default Re: MTRX Studio Wakes up Dead today…*Fairly urgent issue
Sorry to hear that. Can you describe your networks and how you have the device configured -> DHCP, Static, Self-assigned?
https://avidtech.my.salesforce-sites...0001-in-DADman
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-21-2023, 03:35 PM
Hi Jeff -
Thanks for the quick reachout
Looks like an issue with the Mac subnet settings, which have not changed since I put this system together in 2021
I went back to original docs and re-entered everything and she came back up OK. Not sure if the MTRX was a participant in the issue; I restarted it several times to see if I could get it to behave.
At this point, though, I think it was the Mac (2019 'Pro, Catalina)
Cheers, hope you have a great holiday
JW
PS - MTRX is on a separate subnet that carries only the connection with DADman, a MOM, and is used for DVS Dante. All manual IPs etc, no other connections made. Using a OWC Doc as the Mac's network connection, but about to switch that to a Star-Tech. The OWC has always been slightly flaky.
Old 12-22-2023, 04:04 AM
Glad to hear that you sorted it. Happy Holidays!
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 01-30-2024, 08:07 AM
DHARTMUSIC DHARTMUSIC is offline
Having exact problem today with MTRX Studio.
Connection error
Error code:0x80000001
Help. How did you fix with Mac Subnet settings?
Jeff, why is this happening? Seems bad.
Old 01-30-2024, 08:35 AM
Greetings,
The short answer is - this is simply a networking communication error - which often happens when you have multiple network adapters (such as Wired + Wifi) on the same subnet.
It is highly recommended to use manual or DHCP addressing for MTRX devices - and ensure that for all of your networks - you aren't using the same subnets. For example, 192.168.1.x on adapter 1, 192.168.1.x on adapter 2. Don't do that. If possible, turn off wifi and allocate dedicated IP ranges and networks for essential services:
LAN / WAN
MTRX / Dante
EUCON / Satellite / Dolby
If you still have issues feel free to PM me.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
MTRX Studio Connection Issue jschmit Pro Tools | MTRX & MTRX Studio 3 09-01-2023 06:45 AM
MTRX Studio automatic sample rate switching issue AINSLIE Pro Tools | MTRX & MTRX Studio 5 09-03-2022 02:29 AM
Dolby Renderer sync issue with HDX/MTRX Studio remainanon Pro Tools | MTRX & MTRX Studio 7 05-24-2022 02:32 PM
MTRX Studio Activation issue waynejones253 Pro Tools | MTRX & MTRX Studio 17 11-25-2021 02:44 PM
MTRX Studio Bass Management Issue ViciousLullabyz Pro Tools | MTRX & MTRX Studio 5 07-15-2020 09:40 AM
