Old 07-24-2021, 06:08 PM
basehead617 basehead617 is offline
Default Alt Layer for Quantize soft key?
In the Shift-8 MIDI soft keys layout, is it possible to use the fader module Ctrl button to turn the Quantize (top left button) into Quantize 50% and quantize with 50% strength?
I don't really get how the alt layers work..
Old 07-26-2021, 05:26 AM
creativecontrol's Avatar
Default Re: Alt Layer for Quantize soft key?
You can customize any of the QuickJump sections to suit your needs which I would recommend. The Alt layers are a bit more advanced -> essentially multiple pages can be revealed beneath the visible by holding down a modifier switch. I would only leverage this for a function that you rarely visit. For the stuff that you need all the time - stick it on the top level of the appropriate page. Here's a bit more on modifying QuickJump functions:
https://youtu.be/EkafQcvy0c8
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 07-26-2021, 10:30 AM
Jeff
Thanks Jeff - I do see how to do the alternate layer now.. i think quantize 50% would be a good alternate of Quantize but i guess i can’t tell if Quantizing with a specific weight is even euconized
Old 07-29-2021, 06:37 AM
No, these specific Event Operation attributes are not directly accessible via EUCON.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Groove quantize doesn't quantize MIDI note off dmitch Pro Tools 2020 0 07-30-2020 12:30 PM
having mixrack and still using C Layer Rob Warren VENUE Live Sound Systems 5 09-10-2010 01:58 PM
How would you layer this? Jon Martin VENUE Live Sound Systems 9 06-05-2007 02:34 AM
How do I UNDO quantize or groove quantize in PT6.9 Asymmetric 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-24-2005 07:04 PM
What's the best way to layer sounds? Jordan F. Tips & Tricks 1 01-19-2004 07:00 PM
