Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 09-20-2022, 05:12 AM
tcrist77 tcrist77 is offline
Default Add MTRX to Omni for 24 Outs?
My studio presently has an Omni HD and an 8.1 speaker system. I am exploring entering the world of Dolby Atmos and want to add an MTRX Studio. Although it is non-standard, I would like to develop toward an 8.1.8 speaker system. The 16 analogue outs of the MTRX leaves me 1 short of the 17 analogue outs needed.
My question is, is it possible to incorporate the 8 analogue outs on the Omni with the MTRX for a total of 24 analogue outs? Is there any extra hardware needed?
Old 09-20-2022, 05:49 AM
creativecontrol's Avatar
Default Re: Add MTRX to Omni for 24 Outs?
Greetings,
Don't forget that MTRX Studio also has a set of TRS outputs which could be used along side the 16 DB25 line outs.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 09-20-2022, 07:55 AM
BScout BScout is offline
You could get 2 channels if you run the Omni as standalone (don't hook the digilink) after setting up the mixer part. Connect HD Omni ADAT to MTRX Studio, route Omni Mixer tab to monitor outputs.
But the better solution (and more direct) is Jeff's. Use the monitor outputs (1/4" TRS) on the MTRX Studio along with the 16 line-outs on the DB-25. And if you needed 2 more channels, use the headphone outs. They are all independent converters (as you can see in DADman under DA)
Old 09-20-2022, 10:09 AM
Thank you so much Jeff and BScout! I appreciate your time responding.
quick question about the mtrx studio and omni TrackerLe Pro Tools | MTRX & MTRX Studio 4 05-25-2022 12:19 PM
MTRX Studio and Omni darkell Pro Tools | MTRX & MTRX Studio 2 12-15-2021 09:21 AM
FS: DAD AX-32 (Avid MTRX), MADI, Pro Mon & 2 8x Pristine DA Line Outs antonis Buy & Sell 7 10-15-2020 05:47 AM
Omni TRS outs Rectifried Pro Tools HDX & HD Native Systems (Mac) 0 05-29-2013 06:01 PM
