Old 08-16-2022, 01:24 PM
vieris vieris is offline
Default Eucon REC softkey GPIO issue.
So I'm using a S6 Eucon softkey to trigger a GPO from the MTM when Pro Tools goes into Record.
The problem is with preroll the GPO gets triggered with every blink of the track record/arm button. I need it to only trigger when it goes into actual record.
I'd love to hear if anyone knows a fix or a workaround. (Something other than using the GPO on the sync HD)
"Any experiment of interest in life will be carried out at your own expense."
Old 08-17-2022, 11:39 AM
creativecontrol's Avatar
Default Re: Eucon REC softkey GPIO issue.
Greetings,
Are you using standard GPIO functions - where Settings > System > GPIO > Transport Enabled is ticked for Stop, Play Record?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-17-2022, 11:41 AM
Same result from both S6 Legacy GPIO and Eucon softkey GPIO modes. We are running the current S6 code for what it's worth.
Eucon 3.7 Issue KeyplayerG Artist Series 0 05-23-2018 06:31 AM
Eucon softkey delay Nyholm Tips & Tricks 0 05-15-2017 01:54 AM
Avid Control / eucon 3.5 / cubase 9 pro - Two functions on one softkey Feinbeat Artist Series 4 05-02-2017 05:50 AM
Cant save "\" character in Eucon softkey command editor Pliplo Avid S1, S3, Dock and Control App 1 12-30-2015 08:20 PM
PT11 + EuCon 3 -> Lost Custom SoftKey pages from PT 10 ApotheKerry Artist Series 6 10-09-2013 02:13 PM
