Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 06-20-2021, 07:59 AM
Hud Hud is offline
Default Help - PTU can't see MTRX Studio via HDN TB3
Hi all, on the chance there is a pro tools MTRX fan that might see this on a Sunday and kindly help - I am sure this is easy to solve, its just me, PS I have googled for an hour and tried all the advice.
I purchased last week a HD Native thunderbolt unit which is connected via a TB2 to TB3 adapter to my Intel Mac mini Big Sur 11.3.1; the HD Native box has a digilink cable from its port 1 to port 1 of MTRX Studio.
The Dadman app sees the MTRX studio via ethernet. Tick.
Mac mini Big Sur 11.3.1 sees the HD Native thunderbolt connected (when I check system information). Tick
My iLOK cloud account shows digilink io licence is active. Tick
PT-U loads fine. Tick
But when I check in PTU "Setup/Hardware" there is no MTRX Studio visible, only PT aggregate and Mac mini speaker.
Any help appreciated! thanks. H
Old 06-20-2021, 08:49 AM
Default Re: Help - PTU can't see MTRX Studio via HDN TB3
Most likely the HD Driver is being blocked by macOS security settings. Go to System Preferences->Security & Privacy->General and see if there is a prompt to allow the driver to run. If not, you may need to reinstall it and keep a look out for a pop-up window asking you to allow the driver access to the system. There have been a few threads of people that were having problems with the system not showing the pop-up, or giving the prompt to allow the driver. A search of this forum should turn up some additional info and advice if that's the case.
Scott Gatteño
Old 06-20-2021, 10:45 AM
Hud Hud is offline
Thanks Scott will try this....nope, systempref|security does not show any blocks...will keep searching...
Interesting that the Dadman app shows a RED triangle against the Digilink 1 row in the routing matrix
Old 06-20-2021, 12:55 PM
ntp-jl's Avatar
ntp-jl ntp-jl is offline
Which version of PTU do you use? You need 2019.12 or higher when using MTRX Studio connected via HDN/HDX.
Jan Lykke
Business Development Manager
DAD - Digital Audio Denmark
Old 06-21-2021, 07:11 AM
Hud Hud is offline
Jan hi
version 2021.3.1
cheers!
Old 06-21-2021, 10:01 AM
creativecontrol's Avatar
This definitely feel like a driver issue as Scott mentioned.
Does your HDNTB have a red LED lit on it by the headphones?
If you open Audio MIDI Setup > Audio > do you see HDNTB?
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 06-21-2021, 12:32 PM
Hud Hud is offline
Indeed you are right! Re-installed HD drivers with help from Avid support (thanks again guys) and PTU now sees MTRX Studio in setup|hardware.
Thanks for all your responses :)
(I'm going to post another now to do with routing from PTU to MTRX studio after having watched the setup video on YouTube and scoured this forum!)
cheers
H
MTRX Studio with HD I/O nedd Pro Tools | MTRX & MTRX Studio 37 07-04-2023 04:58 PM
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX Studio LFE went bye-bye remainanon Pro Tools | MTRX & MTRX Studio 4 02-20-2022 10:41 AM
MTRX Studio Philharmonic7 Pro Tools HDX & HD Native Systems (Win) 15 08-23-2021 03:16 PM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
