Old 08-02-2021, 11:55 AM
Armando Armando is offline
Default Chassis for HDX and UAD-2?
Any boxes out there that will hold 1-HDX and 2-UAD2 cards?
Armando
Old 08-03-2021, 04:50 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Chassis for HDX and UAD-2?
Really?
https://www.sonnettech.com/home.html
update
https://www.sonnettech.com/product/e.../overview.html
Thunderbolt 2, have not tried TB 3 or 4 Although Sonnet Shows HDX.
They were offering a dip-switch for HDX TB2 speed.
Hard to keep up.
Old 08-03-2021, 05:53 AM
Originally Posted by DetroitT View Post
I contacted Sweetwater and they said no go on the Sonnet Echo. Do you have experience with that combination working??
Armando
Old 08-03-2021, 03:22 PM
DetroitT's Avatar
Hard to keep up.
Old 08-05-2021, 05:48 AM
ejsongs ejsongs is offline
I am using a magma eb7 and have a hdx and uad2 card in there.
EJ
Old 08-05-2021, 06:01 AM
EJ
Thanks! Good to know!
Armando
Old 08-10-2021, 03:50 PM
SaschaP SaschaP is offline
I’m actually in the same boat looking for a 2 slot chassis for my HD Native and UAD cards. There were a ton of thunderbolt 2 chassis that worked for both cards but it looks like there’s an issue with thunderbolt 3?
Does anyone know if I can just use one of the older TB2 chassis with a TB3 adapter? Thanks.
Old 08-10-2021, 04:19 PM
LDS LDS is offline
There is an incompatibility issue between HDX and the Sonnet Echo Express III thunderbolt 3 version. Sonnet's new thunderbolt PCIe enclosures include a special 'HDX mode' which gets around it.
The issue is specific to the PCIe backplane in the TB3 enclosure. A TB2 Echo Express III enclosure works fine. It also keeps working fine if you upgrade the TB2 card in it to TB3.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 08-13-2021, 06:45 AM
creativecontrol's Avatar
Here are the relevant Kbase links as well as a PDF of the same compatibility data:
https://avid.secure.force.com/pkb/ar...-Compatibility
Pro Tools TB Chassis Compatibility PDF
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Thunderbolt Chassis to PCIx Chassis for TDM Laptop Rig Logichead Pro Tools TDM Systems (Mac) 0 06-09-2013 01:42 PM
PT HD5 chassis Ramm1 Pro Tools TDM Systems (Mac) 9 11-05-2010 04:19 PM
Digidesign Chassis? Magma Chassis? BigEvil Pro Tools TDM Systems (Mac) 13 12-13-2008 10:53 AM
Expansion Chassis VS 64 Bit Chassis Latency Touchwood Studios Pro Tools TDM Systems (Mac) 2 08-09-2006 05:03 PM
Bit 3 chassis David E. Brown Storage Subsystems 1 07-10-1999 01:53 PM
