D Command issue
I have a D- Command with 1 fader bank expansion. I keep having issues with Protools not recognizing the control surfaces. It typcally takes a couple of restarts and then things settle in for a few days, then the same error message.
Any thoughts?? |
Re: D Command issue
I have this same issue.
I realize the thread was posted a long time ago, but somewhere we still haven't resolved it. Is there a firmware update we can get somewhere? Or does everyone have this problem? Our ethernet connection should be solid-ish... It's a linksys 5-port hub... Though I've know those to stop functioning at random... Thoughts? |
Re: D Command issue
Firstly, this thread should really be in the ICON forum.
Make sure your Ethernet hub is functional firstly. Honestly, I prefer a switch to a hub always. It's also not a bad idea (if you have a Mac Pro) to allocate one Ethernet port for Surface and one for Wide/Local Network. Check your cables. Did you terminate them yourself or are they off the shelf? What version of Pro Tools are you on? What OS version? Jeff Quote:
Re: D Command issue
You're probably right. I just searched, like a good boy, and found it without really paying attention to where it was... But I'll go take a look over there too...
As I typed that out, I began to question the hub a little more... And I also prefer a switch, I just didn't have one to allocate... We are using a Mac Pro, so also have a dedicated port for the surface. The cables are self-terminated, but we have many lines in-house that are, and it's actually the second set of cables we've put on it and still seen the problem... If there's no newer firmware, or no trick anyone's using, I'd suspect the hub. And I'll see if there's some equipment around I could swap that out with... Jason |
Re: D Command issue
You can try blowing out the existing firmware and reloading it. On each module individually hold down SELECT, SOLO & MUTE on the leftmost channel while powering on the unit. Un-declare and re-declare in the Peripherals window. It should then ask to re-load the firmware.
Jeff Quote:
Re: D Command issue
Thanks Jeff.
I'll give that a whirl and see what it can do, along with hunting down a new switch. Jason |
Keyboard command issue | Cartoonguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-26-2012 06:19 PM |
PT 10.1.2 D-Command meter issue | Audio_Vision | ICON & C|24 | 1 | 04-26-2012 10:50 AM |
D-Command CUE issue | rdavis21 | ICON & C|24 | 1 | 05-05-2010 09:27 PM |
Command 8 Firmware issue | Sixstringer7 | ProControl, Control|24, Command|8 | 0 | 11-18-2009 07:11 PM |
Command 8 Fader Issue | iron_aidan | ProControl, Control|24, Command|8 | 9 | 12-06-2008 10:49 AM |
