Re: Synch X benefits without HDX
Yes, the video ref can be derived from the Atomic Clock input. See here ->
https://avid.secure.force.com/pkb/ar...-Release-Notes Quote:
best, Jeff |
Right. Ok thanks.
Hey Jeff,
Does the same apply with an external, non-atomic, word clock? |
Also, is there a preferred ohm BNC cable to use? 50 or 75? thanks
#16
Great. thanks
#17
So if you're trying to use Sync X without HDX how do you even get ProTools to recognize the Synch unit? It seems as if even you're not using the HDX engine that you need HDX in order for the Synch X to be seen by protools. |
#18
#19
Thanks Jeff but the firmware on the unit is v. 0.1.0.523. It needs to be updated. How do I do that without a serial connection?
#20
And if used in standalone mode there is no control over the unit within ProTools I'm assuming?
Internal Video Synch vs Synch X with Native Cards | Goombot | Post - Surround - Video | 2 | 07-16-2023 10:39 PM |
HDX Benefits? | asounds | Pro Tools HDX & HD Native Systems (Mac) | 17 | 10-05-2017 06:17 AM |
88.2 benefits?? | TREXROCK | Pro Tools TDM Systems (Mac) | 15 | 07-20-2010 05:44 AM |
benefits of ram? | Cawbaby | Pro Tools TDM Systems (Mac) | 3 | 05-18-2008 06:56 AM |
Audio in synch with quicktime, out of synch in FCP | WannabeSQ | Post - Surround - Video | 6 | 09-20-2006 06:47 AM |
