#121
Re: First steps with MTRX Studio
So restarted everything including computer. Launched everything and still no signal in DADMan while ProTools is playing via DVSC and obviously no monitoring on the EuControl App. Not sure why this is happening. I made a video... http://www.christesta.com/jeff/ please let me know what I might be doing wrong and how to fix. Again, I didn't change anything unless something happened in the background that I was unaware of. Thank you |
#122
Can you take a screen shot of everything fully expanded in Dante Controller? I believe there is a known issue with clocking with DVS when using internal ethernet on some computers. Audinate were working on a fix. The work around is to use a USB->Ethernet adapter.
James Richmond https://www.jamesrichmond.com 2019 Mac Pro, 2022 Mac Studio Ultra Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro. Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com Latest Article: Auto-Bounce for Logic Pro Affiliate Links: Auto-Bounce by Tom Salta Dreamhost Web Hosting |
#123
Why did it work fine before then? That doesn't make sense that it would work then stop working without changing anything.
#124
Without seeing the screenshot it is hard to say.
#125
I posted a link to a full video above. Check it out. I'd love to hear if you have any suggestions.
#126
A few things. How are you managing your network for DVS, MTRX ST and IP audio? Is everything self assigned?
Also - it appeared that you had some clock errors in Dante Controller. What is designated as your Grand Master in Dante Controller? Jeff |
#127
Nothing is self assigned. Let me fix the clock errors and see what happens. This what it says in regards to master...
#129
Oh you're right. It is self assigned. I had a friend set that up prior to getting the MTRX. Sorry I forgot that. So I fixed the clocking and now I'm seeing signal in DADMan so that's good but still no speaker selects on the EuControl. Restarted everything and quit the app and still nothing.
#130
Check EuControl > Assign and makes sure the Monitor section is not inadvertently bound to Pro Tools or some other app. It should be locked to DADman while focused.
Jeff |
MTRX Studio i/o | Cheesehead | Post - Surround - Video | 9 | 02-21-2021 08:17 AM |
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card | antonis | Buy & Sell | 9 | 04-11-2020 06:47 AM |
Still no specs on MTRX Studio Avid? | corp | Pro Tools | MTRX & MTRX Studio | 51 | 04-02-2020 05:31 PM |
MTRX Studio - No AES?! | Ryan Young | Pro Tools | MTRX & MTRX Studio | 23 | 02-23-2020 02:13 PM |
analog console, next steps for my studio | badperson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-28-2003 08:03 AM |
