Old 05-12-2019, 10:35 AM
acacia acacia is offline
Default Reverting an S6?
Long story made short... I have a NFR support auth with my S6 that expires in a few weeks. It’s from a past auth situation. I’m current in the process of renewing my support contract and it’s taking time to process with Avid. The one I had has subsequently expired while I’m waiting for my dealer to process my order with Avid. I was advised that the NFR shell in my account would hold me over through this process but it’s not working out that way.
My Avid account populated with the S6 19.5 update and I assumed that meant I would be able to use it with the active auth. I decided to take time this weekend to make an alternate DAW OS to see if there was any chance a separate MTRX issue might improve with 2019.5. Upon moving forward with the S6 side of the update I’ve discovered that I can’t get a bin file to complete it. I’ve reverted my DAW but now I cant go backwards with my S6!
I have a case open with Avid and they’ve ask for patience while they look into this but Monday is right around the corner and I have some intense broadcast deadlines looming. Has anyone successfully performed an S6 Restore 1.0 install and then returned to a version with their original bin file? I’m concerned that the bin file may be a one time auth file and this won’t help my situation. I’m trying to be proactive and investigate options while I wait to hear back from Avid. Being the weekend nothing’s happening quickly and I can’t loose all day tomorrow sorting this out.
Any user insights would be helpful. I’m really kicking myself for messing with this. I always maintain a back door with DAW upgrades but it never occurred to me that there might not be one with the S6. I need a fader to perform volume rides... Thanks!
Luke Rohwer
Acacia Recording & Production
www.acaciarecording.com
Luker[at]acaciarecording[dot]com
Studio 301-703-0035
Old 05-12-2019, 11:31 AM
creativecontrol's Avatar
Default Re: Reverting an S6?
Greetings,
Sorry to hear about your troubles. My immediate recommendation would be to login as Admin on the Master Module (password), uninstall S6 Master Module, and reinstall back to the previous version which I presume you were on S6 18.3.0.244. Your auth should still be valid for the version you were on. Feel free to personal message me for more details and questions.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-12-2019, 11:38 AM
megatracks's Avatar
megatracks megatracks is offline
You’re a great help and support Jeff for the S6 community!!
Avid S6M40-32-5D, MTRX (2), Barefoot MM26, PT Ultimate, CB TMC1 Penta, Chandler RS124, Highland Dynamics BG2, Locomotive Audio 14B, Retro 176, SSL, Trinnov STPro, UAD, BAE, etc.
Old 05-12-2019, 12:31 PM
Thanks for the reply Jeff. When I try to reinstall 18.3 I get a message saying a newer version is present and I can not proceed. That’s why I mentioned the restore 1.0... is that was you mean by uninstall?
Luke Rohwer
Studio 301-703-0035
Old 05-12-2019, 12:39 PM
Correct. You can not install over the top of 19.5 which you have currently. Do the following:
Go to About and logout. Login as Administrator password = password.
Once you get to the windows desktop, Swipe from the right edge of the master module touchscreen (swipe right to left) to bring up the Toolbar and touch Settings> Programs and Features. Select S6 Master Module in the list and touch Uninstall. It will finish and make you reboot. Do so. Log back into Admin and reinstall 18.3.0.244.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 05-12-2019, 01:08 PM
Thank you so much Jeff! FYI, when swiping right to left the menu that comes up didn't offer a programs and features selection. It provided a search option that I was able to find the master module app with. I right clicked on the master module application and was able to uninstall it that way. After that all went smoothly. Im back rolling... Thank you!
Luke Rohwer
Studio 301-703-0035
Old 05-12-2019, 01:10 PM
Glad to hear it.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-16-2024, 09:28 AM
Jeff
Hi Jeff . .
Our MTM is on : 2022.12.1.34 I need to go back to 2020.11.1.10.
When I drag from right to left, select settings, I don't see "Programs and Features ?
Please advise . .
JJ
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 02-16-2024, 03:25 PM
Sounds like you have a newer MTM. Log into the Admin user. The go to the Windows menu in the bottom left corner and touch the Gear. Then touch System, then Apps and Features, Avid S4/S6 Master Module > Uninstall.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-16-2024, 03:59 PM
best,
Jeff
Bang on Jeff.
New replacement MTM received 2 weeks ago.
Thank you for your info.
I will perform next week
You’re brilliant!
Have a great weekend.
Reverting from 7.1 to 64 trouble Smakrabit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-03-2007 12:43 PM
Reverting back to 7.0? AfterimageMetal 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-23-2007 01:25 PM
Bought 7.3, Reverting to 7.1.... sean shannon 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 01-13-2007 01:36 PM
Reverting to 5.3.2 Zoduati 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-18-2004 06:13 AM
Reverting back to 5.01 from 5.1 TimOz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-19-2001 02:21 PM
