"external workstation" install required for 2nd workstation?
Since 2016, I've only ever used one workstation with my S6. But now I have a second workstation that I would like to be controlled by it.
I'm installing EUCON on this second system and see an option to install "External Workstation". Do I need to install this along with the S6 WS software? Or only install "External Workstation" and not the WS software? Thanks!
Pro Tools Ultimate, HDX3 & MTRX + HD MADI 7,1 MacPro, 3.2GHz 16-core, OSX 10.15 S6 M40 48-5, panners, MPM,Dolby Atmos RMU AJA Kona LHi, Sync HD www.ToolshedAudioPost.com www.TheToolshedStudio.com Certified for Dolby Atmos Home Entertainment |
Re: "external workstation" install required for 2nd workstation?
Negative. Simply tick the S4 / S6 Workstation line item from the EUCON unified installer and you are good to go.
best, Jeff |
As always, thanks, Jeff! Just had a curiosity though, when is it appropriate to install the software called external workstation?
This is to be installed on a 2nd workstation for use with a EuControl based surface.
best, Jeff |
Thanks!
S6 pref "Open Windows on Workstation When Editing Mode" broken | raoulb | Avid S4/S6 | 1 | 04-18-2023 01:40 AM |
Error1721 - can't install Eucon Workstation | NewHere | Artist Series | 5 | 07-26-2020 09:23 PM |
PT 2018.12.0. "Open Plug-ins on Workstation When Editing" broken? | karegranat | Avid S4/S6 | 14 | 04-15-2019 05:15 PM |
Can't change external volume from "T" to "R" in workspace. [SOLVED] | take77 | Pro Tools 12 | 0 | 04-09-2016 04:52 PM |
Rare Problem, Genius Required. "Reverse Latency" | DSRecordings | Pro Tools M-Powered (Win) | 3 | 01-30-2010 06:03 PM |
