Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 12-29-2023, 01:23 PM
Picture Start Picture Start is offline
Default MTRX Studio I/O Setup is Confusing
Can anyone else tell me or post a screenshot to their I/O Setup when using a MTRX Studio? I find the fact that you have two mic inputs as 1-2 and two TRS monitor outputs as 1-2 breaks up the usual way of thinking about I/O, which we've all trained ourselves to do, which is in groups of 8/16/24.
Is the move to make an I/O Setup where you ignore the hard channels numbers and just number them how you want to see them? for example:
INPUTS:
TB Mic 1
INST 2
LINE 1-2
LINE 3-4
LINE 5-6
LINE 7-8
LINE 9-10
LINE 11-12
LINE 13-14
LINE 15-16
DIG 1-2
DIG 3-4
DIG 5-6
DIG 7-8
DIG 9-10
DIG 11-12
DIG 13-14
Old 12-29-2023, 02:23 PM
Default Re: MTRX Studio I/O Setup is Confusing
Maybe something like this?
Old 12-29-2023, 02:41 PM
BScout BScout is offline
You can map any physical channel to any place in DADman.
The digilink ins and outs seen in Pro Tools are independently configurable inside DADman to the physical actual connections.
If you want the mic pres and monitor outs in a different location, you can. So you can keep your sets of 8. It is not a "fixed" set up -- it's up to the user.
(also, you should have 64 channels not 32 unless for some reason you aren't using both digilink ports on your HDX card and your MTRX Studio.)
Old 12-29-2023, 02:58 PM
creativecontrol's Avatar
Indeed, the double edged sword that is MTRX + Pro Tools is -> anything is possible! So, documentation is critical.
Figure out how you want to allocate and organize patches and monitors in DADman, then in Pro Tools, create the appropriate IO Setup and save templates, PIOs and everything else that will help you avoid reinventing the wheel.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-29-2023, 03:03 PM
Correct, I'm only with one digilink for the moment. These things were always included, but Avid got cheap along the way. And I bought two of these things, so I need to buy 3 digilinks, aargh.
Yes, I think I'm finding the patchability will allow me to make I/O look how I want. Like everything in DADMan, you have to come around to ITS way of thinking. But already possibilities are revealing themselves.
Old 12-29-2023, 03:09 PM
best,
Jeff
Yes, that seems to be the best order of operations: DADman > Pro Tools. I'm getting there, little by little.
Old 12-30-2023, 01:22 AM
LDS LDS is offline
The DAD/MTRX stuff is quite divergent from the previous decades of integrated Avid interfaces where the I/O page directly reflected the physical inputs and outputs on the digilink interfaces, but it is very flexible & powerful stuff. For DAD/MTRX stuff, I always found it helpful to compartmentalise the various I/O routing pages.
- The Pro Tools I/O menu only handles the routing of the digilink ports directly on your HD native or HDX card.
- DADman handles the I/O routing of all the physical inputs and outputs on your MTRX Studio, including its digilink ports.
In so many way, DADman becomes the epicentre of everything happening in your studio. It handles the talkback. It handles the monitoring. It handles the routing of analogue and digital I/O. The Pro Tools I/O page becomes something much simpler, as it is just there to send digilink audio between Pro Tools and DADman.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 12-30-2023, 02:31 AM
uptheoctave uptheoctave is offline
Yep, this is how I do it too.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 12-30-2023, 11:18 AM
I appreciate this framing. It makes it easy to understand the mindset behind it.
Old 12-30-2023, 11:32 AM
nsureit nsureit is offline
I have connected both Digilink cables from MTRX Studio to HDX card = 32 hardware device I/Os. Most are outboard preamps, plus several compressors.
Dual MTRX Studio setup Goombot Pro Tools | MTRX & MTRX Studio 12 04-28-2023 01:20 PM
MTRX Studio with Hd Native and HD I/O 16x16 Analogue. Anyone with this setup? baslotto Pro Tools | MTRX & MTRX Studio 1 01-24-2023 01:44 AM
Dante Virtual Soundcard - MTRX Studio Setup TrentWilliams Pro Tools | MTRX & MTRX Studio 10 07-22-2021 06:52 PM
MTRX Studio Audio Midi Setup Goombot Pro Tools 2020 6 02-25-2021 08:35 AM
Advice on MTRX Studio setup please Cheesehead Pro Tools | MTRX & MTRX Studio 9 09-03-2020 03:01 AM
