Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | MTRX & MTRX Studio
Old 12-20-2021, 10:37 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Default 3rd Party SFP for MTRX
Does anyone know if the SFP's used in the DUAL MADI option cards for MTRX are proprietary? i.e. would a 3rd party SFP work? Or are the AVID supplied ones modified an anyway from standard form factor or functionality? Resorting to this in the absence of any being available before new year. TIA!
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 12-20-2021, 11:22 AM
creativecontrol's Avatar
Default Re: 3rd Party SFP for MTRX
I would highly recommend not using arbitrary SFP modules with MTRX.
From the MTRX Kbase:
https://avid.secure.force.com/pkb/ar...s-MTRX-Support
Qualified SFP Modules:
SFP's that are distributed by NTP and/or Avid are supported (contact your reseller)
SFP's from other third parties may not work with Pro Tools | MTRX and are not recommended
MADI SFP Compatibility:
What is the difference between 850nm and 1300nm SFP's?
850nm, which uses 100BASE-SX cable, is a lower cost alternative. This is due to the use of short wavelength optics, which are significantly less expense than the long wavelength options used in 100BASE-FX. Maximum 850nm cable runs are approximately 1,000 ft., while 1300nm can travel as far as 6,600 feet.
Products that use the 1300nm wavelength include the Pro Tools | HD MADI, as well as most digital live sound consoles, such as those by Soundcraft, Studer, and Yamaha. Consult your owner's manual or the manufacturer for your system’s optical wavelength.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-20-2021, 07:45 PM
BScout BScout is offline
They are standard SFP transceivers. Just have to meet all the specs of the originals.
Avid's "support" is up to them but I had this discussion with DAD/NTP a long time ago when we needed transceivers in a rush.
Old 12-20-2021, 07:59 PM
AINSLIE's Avatar
Thanks - we actually found AVID ones, but before that we found some 3rd party with the exact same model / part numbers / stickers on them. We will try them to see if they work as an experiment when its not critical and report back for anyone else who finds this thread in a pinch.
Old 12-23-2021, 09:19 AM
AINSLIE's Avatar
Jeff - I sourced the AVID SFP's so we are set somewhat. Question - can I feed MADI optical from that multimode 1300nm SFP in a dual Madi card in a MTRX to an AVID HD MADI interface fiber input on a separate machine? I can't see in the manual if they are compatible / same frequency. If not is the only way to connect via 850nm or COAX? Any help appreciated!
Ainslie
Jeff
Old 12-23-2021, 09:28 AM
Yes, the Optical MADI Module - Multi-Mode SFP 1300nm is the one you want if you are interconnecting with an HD MADI interface.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 12-23-2021, 09:44 AM
AINSLIE's Avatar
You help is exceptional thankyou Jeff!
We will be taking in 368 channels of MADI into the MTRX. Then patching and recording up to 192 tracks at a time in PT. Being able to label and pre save the DadMan and Protools configurations is pretty amazing - allowing us to do it all in one machine with no physical repatching required (at our end) over the 3 days we will be recording. Again many thanks fo your answers.
Old 12-23-2021, 09:46 AM
Happy to help. Good luck with the recording!
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Difference between MTRX and MTRX Studio? snowplaysmusic Pro Tools | MTRX & MTRX Studio 4 11-26-2022 08:48 AM
MTRX Studio tuning v MTRX SQP card Goombot Avid Pro Mixing General Discussion 9 07-15-2021 11:00 AM
MTRX-> HDX or MTRX->Dante ArmyofLight Pro Tools | MTRX & MTRX Studio 34 04-08-2021 04:51 PM
FS: MTRX 2x 8 Line Input Pristine Card 1x MTRX SPQ Card antonis Buy & Sell 9 04-11-2020 06:47 AM
MTRX Box JSR Avid S4/S6 4 11-01-2017 12:46 PM
