MTRX2 Digilink card 32 ins and out's only
I have a MTRX2 with HDX2 and I bought a Digilink card to go with it. I am only seeing 16 A/Ds and 16 D/A's not the full 32 and 32. I've reseated the card and switched to a different slot and still the same. Both HDX cards passed Digitest multiple times. Is there some kind of firmware thing I'm missing? I have the current version of DADMan (5.6.9.1). My firmware version is in the included picture and pic of my DADMan Config. (There are red triangles because I have the Digilink's unhooked). I guess I'm just wondering if I'm missing some sort of firmware update or if by chance, something is wrong with the card.
Re: MTRX2 Digilink card 32 ins and out's only
You've likely got the Digilink connection mode wrong in the MTRX II.
See MTRX 32x32 on pp 32 of the MTRX II Guide. Invoice is in the mail. Last edited by Darryl Ramm; 09-16-2023 at 12:40 AM. |
Ah. I had a feeling I was missing something simple. I’ll recheck in the morning. Thanks
It's not that.
It's you are running at 192kHz. Channels get halved. For reference (this is counting inputs+outputs) But you are also missing the second digilink entry. That happens when you are in Pri/Exp mode instead of Pri/Pri mode.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I would also kill the Avid Audio Server - and set the Adapt to in DADman to DigiLink 1. When Pro Tools is Quit / Launched there is a handoff between the CoreAudio driver and the direct HDX (HD Drivers). If you will (presumably) never use CoreAudio - you can simply prepend an x (xAvidAudioServer) to the path -> Macintosh HD > Applications > Avid > AvidAudioServer.
As the other fine folks already mentioned, under Conf > DigiLink - you want to set DigiLink Mode to Pri/Pri and port emulation to MTRX 32x32. Jeff |
That was it. Switching the Digilink mode. Thanks guys. Thanks Jeff
Avid Pro Tools HDX card w/ Digilink cable and PT keyboard | songwritersoul | Buy & Sell | 4 | 02-04-2023 12:51 PM |
Digilink card starting problem | Pinball Wizard | Pro Tools HDX & HD Native Systems (Win) | 0 | 01-28-2021 09:51 AM |
HDX Card Benefits w/o Digilink I/O Connected? | Spindrift300 | Pro Tools HDX & HD Native Systems (Mac) | 2 | 05-06-2019 06:44 PM |
Lynx Aurora 16 HD (w/ LT-HD card) + free 12' Digilink Cable - $2250 | SHIRK | Buy & Sell | 0 | 06-01-2013 07:38 AM |
