Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Sync X & SYNC HD
Old 08-15-2023, 06:20 AM
creativecontrol's Avatar
Default Re: Synch X benefits without HDX
Yes, the video ref can be derived from the Atomic Clock input. See here ->
https://avid.secure.force.com/pkb/ar...-Release-Notes
Originally Posted by Goombot View Post
I wish they did. It's really silly. On another note with the Sync X I have a question about the atomic clock input. If you clock the Sync X to an atomic clock does that just affect the word clock output of the sync x or does that affect the vid ref out in some fashion also?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-15-2023, 11:39 AM
Goombot Goombot is offline
Right. Ok thanks.
Old 08-16-2023, 11:27 AM
Hey Jeff,
Does the same apply with an external, non-atomic, word clock?
Old 08-17-2023, 12:17 PM
Also, is there a preferred ohm BNC cable to use? 50 or 75? thanks
Old 08-17-2023, 12:21 PM
75 ohm -> see here:
https://resources.avid.com/SupportFi...nc_X_Guide.pdf
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-17-2023, 12:30 PM
Great. thanks
Old 08-23-2023, 12:23 PM
Originally Posted by creativecontrol View Post
Yes, SYNX X has significant value when used to resolve the sample clock of Pro Tools audio peripherals to a frame edge reference. Without an HDX system, SYNC X is a stand-alone Master Clock, Word Clock Distributor, HD Video Reference Generator, and SMPTE timecode generator.
best,
Jeff
Hey Jeff,
So if you're trying to use Sync X without HDX how do you even get ProTools to recognize the Synch unit? It seems as if even you're not using the HDX engine that you need HDX in order for the Synch X to be seen by protools.
Old 08-23-2023, 12:39 PM
Standalone Mode:
https://youtu.be/t1QMWpVKLmA
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 08-23-2023, 01:00 PM
Thanks Jeff but the firmware on the unit is v. 0.1.0.523. It needs to be updated. How do I do that without a serial connection?
Old 08-23-2023, 01:02 PM
And if used in standalone mode there is no control over the unit within ProTools I'm assuming?
Internal Video Synch vs Synch X with Native Cards Goombot Post - Surround - Video 2 07-16-2023 10:39 PM
HDX Benefits? asounds Pro Tools HDX & HD Native Systems (Mac) 17 10-05-2017 06:17 AM
88.2 benefits?? TREXROCK Pro Tools TDM Systems (Mac) 15 07-20-2010 05:44 AM
benefits of ram? Cawbaby Pro Tools TDM Systems (Mac) 3 05-18-2008 06:56 AM
Audio in synch with quicktime, out of synch in FCP WannabeSQ Post - Surround - Video 6 09-20-2006 06:47 AM
