Old 02-07-2019, 04:50 AM
priorytools priorytools is offline
Default Track/channel order effects layout ?
If I have say, drums on 1>8 & make a layout with just them in, but then move say the ambiance tracks to the left of the drums, effectively making the ambience tracks 1>8 my drums layout now contains the ambience . . ?
What setting do I have set wrong ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 02-07-2019, 10:21 AM
creativecontrol's Avatar
Default Re: Track/channel order effects layout ?
Greetings,
I'm trying to infer exactly what the workflow is. It sounds like you are making a modification to an existing layout by adding new tracks and reordering / shuffling. If this is performed with the Auto-Save Changed Layout on Recall Mode preference set to Update - then you will simply be updating a modified layout. If set to Save to New - it will automatically add a new layout when modifications are made. Does this answer your question?
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 02-07-2019, 11:24 PM
Originally Posted by creativecontrol View Post
Greetings,
best,
Jeff
Yes, thanks Jeff.
Layout of the channel mode OLEDs made Avid S1, S3, Dock and Control App 0 02-23-2015 03:18 PM
Q from mackie user about channel layout jesse p Artist Series 6 07-29-2011 06:07 AM
creating/opening and OMF file and proper layout when cutting effects lalalandguy Post - Surround - Video 1 02-23-2010 02:48 PM
Order region list in the order the regions are on a track Wesselink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-30-2009 06:53 PM
HOW Poll on channel layout Scott Fahy VENUE Live Sound Systems 4 11-13-2008 08:36 AM
