Old 10-05-2003, 10:34 PM
Jonathan Gordon Jonathan Gordon is offline
Default 64 voices w/HD 2, PT 5.3.1 ?
Hi All:
I'm trying to get my HD 2 system to run in 64 voice mode. I keep getting -6028 errors and sometimes -6039 errors when I try to do this regardless of how I allocate the audio. 48 voice mode works like a charm using a single Cheetah drive for audio. The Answerbase info on these error messages does not seem useful.
System is HD2 w/ 192 I/O and Sync I/O on a quicksilver G4 w/ an ATTO EPCI-DC card running two 18 gig Cheetah drives. PT v 5.3.1, Mac OS 9.2.2, 4th PCI slot has an Aurora Fuse card in it. Recently added a 200 Gig 7200 rpm Oxford 911 chip set Firewire drive. Allocating some audio to the firewire drive does not seem to help.
Control is via a HUI which, like my other MIDI devices, is hooked up to an Opcode Studio 4 interface connected via a Griffin G-port mod.
I am also getting MIDI overflow problems fairly regularly, which I suspect implicate either the HUI or the Studio 4/Griffin configuration.
I know this is a rather offbeat setup with a lot of older grandfathered equipment- Is there anything in this setup that suggests why I am having trouble getting 64 voices?
Any thoughts on the MIDI logjams?
Thanks a lot!
JG
Jon Gordon
Old 10-08-2003, 08:18 PM
Default Re: 64 voices w/HD 2, PT 5.3.1 ?
Thanks to all who looked at this post.
It appears that the problem is a funky HD Process card, combined with the fact that the loop sync cables were not hooked up between the 192 I/O and the Sync I/O. Thanks, Digi tech support.
Who knew?
JG
Jon Gordon
ran out of voices, what is this? srsoundlab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-29-2007 02:37 PM
More voices in this new PT LE 7.0 ??? MMC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 59 09-27-2005 01:19 AM
Voices,Voices,Voices..How to do it!? 002?MBox?HD? TheMadStudent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-07-2005 09:16 AM
G4 PB and 6.x LE. How many voices? tlester 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-07-2004 04:41 PM
more than 32 voices with PT/24 ? phil kerg Pro Tools TDM Systems (Mac) 2 02-01-2003 06:41 PM
