Old 08-27-2001, 10:36 PM
mix2much mix2much is offline
Default Unable to monitor spdif input on digi 001
howdy everyone. Here's my dilemma-
I buss 8 channels of A-dat optical into a yamaha 03d. The rest of the channels are bussed to stereo outs of the digi, which is analog 1/2 and spdif out. I can monitor everything fine on the yamaha board, and I send a stereo mix of everything from the 03d mixer back to the digi via spdif out of the yamaha. When I bounce to disk, the spdif signal sent from my mixer doesn't end up on the mix. I also cannot hear the returns (spdif) from the yamaha if I monitor from the digi 001 with my spdif cable going into the input on the digi. I think I'm missing a small but vital step. Any suggestions?
Old 08-28-2001, 08:30 AM
Default Re: Unable to monitor spdif input on digi 001
Thanks Brent. I'll give that a try.
Old 08-29-2001, 08:36 AM
digi98 digi98 is offline
mix2much - do you have optical spdif output
source on your 02r that you can send
spdfif signal
to optical input on digi pci card?
Have you gotten this to work?
How?
Old 08-29-2001, 09:12 AM
Yes, the optical works fine both in and out of the pci card. It was actually very easy. In the mix window, I chose the track I wanted to send to the board optically, and onthe output of that channel I had to change it from analog 1/2 to A-dat mono 1 (or whatever channel number you want it to be) I made sure my board was slaving to the spdif in clock of the digi 001.
Digi 002 - Can't Monitor Input ragingcortez 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 04-28-2011 07:44 AM
where do I monitor optical input on the digi 002 or pro tools7.4.2 dbluprecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 02-09-2010 10:41 PM
SPDIF input Dropout on Digi 001? fingerz88d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-31-2005 11:09 PM
switch auto input and input only monitor with midiprotocol mmestudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-27-2003 03:51 PM
No SPDIF input for DIGI 001 flyin dread 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 09-19-2000 05:02 AM
