Old 07-22-2002, 11:37 AM
denbee denbee is offline
Default Mbox sound input in Apple Sound Control
Is there a way to choose the Mbox as the sound input device for the MAC?
Old 07-22-2002, 02:14 PM
Default Re: Mbox sound input in Apple Sound Control
The reason for a USB audio device is for both both inputting and outputting audio. Right now the Mbox works just fine as an output device but only works as an input device with Pro Tools. The Mbox does not show up in the Apple Sound Control Panel so it cannot be used to input audio into other programs.
Old 07-22-2002, 06:18 PM
DesertDude DesertDude is offline
right you are & its a real shame... go figya [img]images/icons/grin.gif[/img]
[img]images/icons/cool.gif[/img]
DesertDude
1.25 Alu/1.5 ram/10.3.4
PTLE 6.4-002R-Live-Reason
Old 07-23-2002, 12:46 AM
mBoxLuvr mBoxLuvr is offline
as output it works fine by selecting Digi in Sound Panel.
what exactly do you mean as input?
like if your in Adobe Premiere and would like to capture sound using the Mic pres on the mBox?
Old 07-23-2002, 07:27 AM
Mightypudge Mightypudge is offline
And it can't be used as an output device under OS X. Yet.
Andrew
Old 07-24-2002, 12:08 AM
jes's Avatar
jes jes is offline
you can do it in specific applications by using the Digidesign Direct I/O ASIO driver. i use it that way in MAX/MSP and SuperCollider, it works then as input and output.
however, when using Quicktime midi also, it doesn't send it out the mBox, which is strange. i don't quite understand that. like if i am playing a max patch, all the audio goes in and out the mBox, but the QT midi sounds are coming out of the powerbook's speakers!
thast doesn't happen with the AMIII card...
http://www.jonathansegel.com
Mac Pro 5,1 3.06ghz 64GB RAM
Macbook Pro 2.8Ghz 16GB RAM
PT 2022.10
UAD-2 Apollo Quad, PCIE and Satellite
Mbox without any input sound Luskar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-17-2010 07:52 AM
Mbox with no input sound wickedfpoop 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 04-08-2009 11:02 PM
mbox as sound input device??? comforteagle 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-18-2005 09:48 AM
Mbox as Sound Input GrimCoffee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-27-2003 11:08 AM
sound control panel/audio input? anders Tips & Tricks 1 07-13-2000 09:28 PM
