Old 05-23-2023, 05:45 AM
Talisker Talisker is offline
Default Pro Tools often struggles to quit
I run PT 23.3.0.89 on a mac mini 2020 M1 and on mac os 12.4. And I use Rosetta to run PT. And more often than not, PT freezes when I try to quit. Not a big deal, nothing got lost so far, still I like to investigate the reason. Then again, when I stop using Rosetta the issue might be gone anyway, but if someone has an idea.....
Mac Mini M1, 16 GB Ram, OSX 10.181.1,Focusrite Scarlett 18i20,Behringer ADA 8200,Pro Tools 2022 2xGlyph hard drive 750GB
Old 05-23-2023, 05:53 AM
its2loud its2loud is offline
Default Re: Pro Tools often struggles to quit
This is I known bug and has been discussed on the DUC.
https://duc.avid.com/showthread.php?...quit+pro+tools
Old 05-23-2023, 05:56 AM
Oh, ok thanx
Old 05-23-2023, 07:50 AM
Ben Jenssen's Avatar
For what it's worth; Since I went from M1 to M2, and Big Sur to Ventura, and PT2022.12beta to 2023.3, all in one go, I have not seen it ONCE!
Old 05-23-2023, 10:13 AM
Eric Lambert's Avatar
I still see it (I'm using the latest versions of everything), even when running in Native mode, and it seems to depend almost entirely upon the plugins used in the session. For instance, if there's a Lexicon reverb -- even just one -- it will take up to 20 seconds longer to close the session than if there was no Lexicon plugin.
Old 06-01-2023, 06:43 AM
685 685 is offline
I'm seeing it more than usually on the Mac Studio running 2023.3 Ultimate.
System info
https://duc.avid.com/member.php?u=57185
"please stop OVER-complicating simple things"
Sample rate struggles lavastudios Pro Tools 11 2 12-30-2020 10:24 PM
Pro Tools refuses to quit. Have to force quit. SD2 Pro Tools 10 13 01-23-2014 08:21 AM
Pro tools doesn't quit when I quit. lucky lee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-18-2005 03:34 AM
Pro Tools must force quit to quit losttimestudios Pro Tools TDM Systems (Mac) 3 03-21-2005 09:32 AM
My struggles with ProTools MIDI... stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-24-2003 11:19 AM
