Old 07-19-2022, 02:37 AM
Tungstenman Tungstenman is offline
Default 2022.6 Template with saved media crashing Pro Tools.
This afternoon I created a new template (with media), as I've done many times before, yet suddenly when I tried to use it, the audio files don't link and Pro Tools gives me the beach ball of death, locking up until I force quit.
I trashed my prefs and had the same result.
I then tried to use another template - that I know has worked in the past, created in June - and had the same issue. I then tried a template I'd created over a year ago, and that worked fine.
After this I thought I'd try the more recent ones that hadn't worked with no success. I even left it trying to link for over half an hour, but came back to find the beach ball.
This is the first time I've tried to use templates since updating to 2022.6
Running M1 Mac Mini, 16bg ram, Monterey, PT 2022.6
Audio files are all present and in the same folder as the pxtx file. I also dialed in remotely to a second machine, and the new template worked fine on that machine (not updated to 2022.6).
Maybe a unique problem, but has anyone had a similar experience or ideas of what to try next?
Old 07-19-2022, 08:52 AM
Default Re: 2022.6 Template with saved media crashing Pro Tools.
You will need to dig deeper to solve this. Can you create from a template that has no media? Try creating a new template session and import the media(creating a new version of the old template).
Old 07-19-2022, 04:50 PM
Yep, sorry should have mentioned, I can create from templates with no media.
I can drag the media in, but as I work for a lot of regular clients having the media assets already placed in the session is a real time saver. Just odd that it was working fine and suddenly are acting like they're corrupted.
Old 07-19-2022, 05:06 PM
If it's only on your computer I would suspect other stuff like plugins that happen to interact with these sessions. So you likely just have to run though that troubleshooting.
Old 07-26-2022, 01:10 PM
SFXgeek SFXgeek is offline
Any luck with this? We just came across the same issue in our mix room, running PT Ultimate 2022.6
Old 07-26-2022, 09:25 PM
Dizzi45Z Dizzi45Z is offline
I'm also having this issue. I especially notice this crash happen when I am importing a clip that was created in a project with a different sample rate than the one I am importing to.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 07-28-2022, 04:36 AM
lexkon lexkon is offline
Ditto to OP.
Using 2022.6 on 13in 2020 Intel MBP running macOS 12.5
Templates with plugins seem to be absolutely fine and the crash happens when there's media associated with the template. The only workaround I've got is to import session data but obviously not the ideal scenario when this wasn't an issue in the last version of PT.
Hopefully Avid can address this quickly 🙃
Old 07-28-2022, 05:20 AM
tamtamstudio tamtamstudio is offline
In media bin or clips in templates have got region groups?
In this case happened to me, ungroup/consolidate and resave template.
Let's see if it works.
best
Corrado Magalotti
Tam Tam Recording studio
Old 08-09-2022, 01:41 PM
derekcampbell derekcampbell is offline
Same issue for me. I use saved media templates like crazy. Only work around I know of is to create a brand new blank session, name the project as you would with the template, and import session data from a similar project.
In my case, I edit podcasts and I just import the previous episode's project. Also, I'm sure you can import the session template from the folder itself but I've never needed to.
Old 08-09-2022, 04:55 PM
Nick Cipriano Nick Cipriano is offline
This is active on another thread. Apparently Avid has been aware of this for several weeks.
https://duc.avid.com/showthread.php?t=420891
ProTools 2022.6.0 Plug In Crashing Issues postpro Pro Tools HDX & HD Native Systems (Mac) 4 07-14-2022 01:24 PM
Pro Tools 2022.6 with Avid Control 2022.4 stargazer Pro Tools 2 07-01-2022 07:32 AM
Pro Tools 2022.4 CRASHING upon LAUNCHING on Monterey 12.3.1 nightowls Pro Tools 7 06-10-2022 01:16 AM
Unable to double click to open a saved template John Rivers Pro Tools TDM Systems (Mac) 5 07-31-2006 03:49 PM
