Old 01-14-2022, 09:17 AM
RicardoEscallon RicardoEscallon is offline
Default MC Mix displays show up on my main screen
The craziest thing is happening today. The displays of my Euphonix MC Mix are showing up on my main screen, taking about the upper third of it, with a black background and display what usually should only be on the LCDs of the MC Mix. I see channels 1, 2, 7 and 8. I had never seen this before.
I am attaching a screen shot.
If I turn off the unit I recover my normal screen.
I am running
Mojave 10.14.6
EuCon Version 2021.10.1.29
4.8.3.29
ProTools Ultimate 2021.12.0
File Type: jpg Screen Shot 2022-01-14 at 11.14.45 AM.jpg (52.6 KB, 0 views)
Old 01-14-2022, 09:50 AM
its2loud its2loud is offline
Default Re: MC Mix displays show up on my main screen
I am running
Mojave 10.14.6
4.8.3.29
This has a been a reoccurring issue when using three displays on a Mac. Quitting and restarting EuControl will fix it.
If you have the control surfaces powered on before booting up the system, this occurs more often.
If you power on the control surfaces while the system is booting, this occurs more often.
If you wait to power on the surfaces until after EuControl is running, this occurs less often.
Old 01-14-2022, 10:01 AM
Thanks, I will try that
Old 01-14-2022, 11:47 AM
I ended up reinstalling EuCon, and now it works fine.
I only have two monitors, not three.
Old 10-10-2023, 10:05 AM
adogg4629 adogg4629 is offline
I've run into this as well, but I only have two screens on my Mac. I uninstalled and re-installed it as well as all the Avid software, and it still is present. It only takes up a sliver of the upper left portion of my ultra wide screen. I don't have this issue when using the same setup on my PC set up.
Differentiating between main screen and edit screen wkdreskin Pro Tools 2018 7 03-08-2019 08:28 AM
Main screen Red Raven Audio Pro Tools 12 14 07-25-2016 08:24 PM
Avid is not sure about HDX1 on my Mac Pro with 6 flat screen displays connected. PICS conrad787 Pro Tools HDX & HD Native Systems (Mac) 39 06-08-2012 05:51 AM
Is it possible to show subframes in the Main Counter? lyrad Post - Surround - Video 0 05-26-2010 11:43 AM
O/T. Flat screen displays hornedrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-28-2001 08:03 PM
